Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools file name conventions
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
'Number of device specific dated files to retain' option is not working
You have set the Number of device specific dated files to retain option, but the activity is deleting all files.
This issue is likely due to the file naming convention you have used to replace the default CatTools file naming convention. CatTools default file naming convention uses, for example:
Config.Current.Running.Cisco_Router_2.txt
If you are using a convention which does not place a period at the end of the device name, such as Cisco_Router_2 in the above example, CatTools cannot group the files relating to the device correctly. For example, if you are using a file naming convention such as:
Cisco_Router_2-backup.txt
CatTools cannot group the Cisco_Router_2 files together correctly, so all files are therefore deleted.
Following the device naming conventions for Kiwi CatTools. In the above example, is to change the dash '-' in your own naming convention to a period.
Specifically, Cisco_Router_2-backup.txt must be renamed to Cisco_Router_2.backup.txt
