Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Script functions in Kiwi CatTools
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Kiwi CatTools includes several built in functions available to Client scripts. Use the "cl." prefix to access a function from the client. For example:
cl.Log 1, "Expected response not received from command ..."
Functions
ConnectHost() As Boolean
  • Attempts to connect to the current host specified in CurDevHostAddress.
    • True = the connection is successful.
    • A warning message is logged if a connection attempt fails.
  • The connection is attempted three times before failing. After three failed attempts, an error message is logged.
ConnectHostSingleAttempt() As String
  • If the connection is successful, a value of "OK" is returned. Otherwise the error description is returned.
  • This function is called 3 times by ConnectHost.
ConvertToFilename(Filename as variant) As String
  • Converts a device name into a suitable filename.
  • Replaces any invalid characters in the filename with an underscore, including quotes and spaces. The following characters are considered invalid in a filename: "&+?:;,()=|\/<>*^%@
CreateFile(Filename) As Boolean
  • Attempts to create the specified file even if the path does not exist.
    • If the file already exists, no action is taken.
    • If the file does not exist, the path and a file are created. The file is 0 bytes in length.
CurrentDateStamp(Format as long) as String
  • Returns the current date formatted based on the value of "Format".
  • Format values:
    • 0 = ISO Format (YYYY/MM/DD)
    • 1 = US Format (MM/DD/YYYY)
    • 2 = UK Format (DD/MM/YYYY)
CurrentDateTime(Format as long) as String
  • Returns the current date and time formatted based on the value of "Format".
  • Format values:
    • 0 = ISO Format (YYYYMMDDHHNNSS)
    • 1 = US Format (MMDDYYYYHHNNSS)
    • 2 = UK Format (DDMMYYYYHHNNSS)
CurrentDateTimeStamp(Format as long) as String
  • Returns the current date and time without separators, formatted based on the value of "Format".
  • Format values:
    • 0 = ISO Format (YYYY/MM/DD HH:MM:SS)
    • 1 = US Format (MM/DD/YYYY HH:MM:SS)
    • 2 = UK Format (DD/MM/YYYY HH:MM:SS)
DBCheckScheduleOption(ScheduleNumber, Option Number) As Long
  • Returns the activity specific option check box value.
    • 0 = unchecked
    • 1 = checked.
  • Each activity has 10 optional data values that can be set for the activity. Pass the activity number and an option value - from 1 to 10 - and the return value of the specific option check box is returned.
  • Refer to the activity .ini file for details of each specific option.
Sub DBDevicesClearCurDevFields()
  • Clears all the current device variables and sets them to "".
Sub DBDevicesGetAllFields(DeviceName)
  • Locates the specified device in the database and loads all the fields into the CurDevXXX variables.
  • To check if the function worked: check len(CurDevName) > 0
Function DBDevicesGetField(DeviceName, FieldName) as Variant
  • Returns the data contained in the field "FieldName" of device "DeviceName" from the database file.
  • Returns blank if the data retrieval fails.
Function DBScheduleGetField(ScheduleNumber, FieldName) as String
  • Returns the data contained in the field "FieldName" of activity "ScheduleNumber" from the database.
Function DeleteFile(Filename) As Boolean
  • Deletes the specified file and returns true or false based on if the file exists after the delete attempt.
    • True = File deleted.
    • False = File still exists and was not deleted successfully.
Sub DisconnectHost()
  • Closes the active connection to the current device
Function FileExists(Filename) As Boolean
  • Tests to see if the specified file exists.
    • True = the file is found.
    • False = the file is not found.
Sub FlushRxBuffer()
  • Flushes the data found in the receive buffer and waits until there is no further data being received from the active socket.
Sub InfoUpdate(Message)
  • Sends an info update message back to the main program.
Sub LogToFile(Filename, Data, Append)
  • Opens a file for writing. Writes the data stored in Data to the file.
    • Append = 1, the data is appended to the end of the file.
    • Append = 0, the file is overwritten with the new data.
Function Ping(Hostname As String, Timeout As Long, PingCount As Long, ProcessID As Long) As String
  • Attempts to ping the host name and returns the results in the format:
    !!!!! TAB 100% TAB 10 TAB 100 TAB 80 or ..... TAB 0% TAB TAB TAB
    • Hostname is the IP address or hostname of the device to ping Timeout is in seconds. The default is 5 seconds.
    • PingCount is the number of Ping echo requests to send. Default is 5 pings.
    • ProcessID is the current processID (cl.ProcessID). This is used to identify the sent ping packets so that the responses can be tied back to the correct process that sent them.
  • The min, max and average response times are calculated from any ping echoes received.
  • The return data is tab delimited for easy parsing and reporting.
Function ReadFromFile(Filename) As String
  • Reads the contents of the specified filename and returns the data as a string value.
  • A "" value is returned if the file doesn't exist or contains no data.
Function ReplaceClientFilenameVariables(Filename) As String
  • Replaces the %Variable% item with the associated value.
    • %AppPath% = cl.AppPath
    • %GroupName% = cl.CurDevGroup
    • %DeviceName% = cl.CurDevName
    • %DateISO% = cl.CurrentDateStamp(0) ("YYYY-MM-DD")
Sub SaveResults(Data, Append)
  • Saves results data into separate files.
  • The file name is created from the device name and UniqueFileID set in the Main script in the format:
    Filename = cl.AppPath + "\ClientTemp\" + UniqueFileID + ConvertToHex(DeviceName) + ".txt"
  • DeviceName is converted to hex format to remove any invalid characters present.
Sub SendData(MessageText)
  • Sends the string in MessageText to the current connection.
Function WaitForMultData(Mult, Choices, Timeout) As Long
  • Monitors the RxBuffer for data contained in the Mult() array.
  • If a match is found, the array index value is returned.
    • A return value of 0 indicates that no match was found before the timeout occurred.
  • The timeout is specified in seconds and the variable cl.RecDataTimeOut is usually passed as this value.
  • Choices indicates the number of elements in the Mult array. For example: Mult(1) = "Login:" Mult(2)= "Password:", Choices=2
Function ReplaceControlChrs(Message) As String
  • Replaces any control characters less than ASCII value of 32 with a text string of the numeric value.
  • For example: A tab character (ASCII 9) becomes <009>.
  • This is used when logging debug data to the display or file for later analysis.
cl.Log
Sub Log(Priority, Message)
  • Sends a log event message back to the main program.
  • Use one of the following priority codes to classify the message:
    • 4 = Debug
    • 3 = Info
    • 2 = Warning
    • 1 = Error
