Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Registry settings - PingTimeout
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
This Kiwi CatTools registry setting specifies the maximum time (in seconds) for the Manager to wait for the device's echo reply message after sending the echo request.
Section (32-bit Windows OS) HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds\CatTools\Properties
Section (64-bit Windows OS) HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SolarWinds\CatTools\Properties
Value (STRING) PingTimeout
Default value 3000
