Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Registry settings - NTServiceSocket
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Kiwi CatTools Manager connects to the service via TCP port 4400. This allows the two applications to communicate. If another process is already using this port, use the Kiwi CatTools registry to change the port value.
Section (32-bit Windows OS) HKEY_LOCAL_MACHINE\SOFTWARE\SolarWinds\CatTools\Properties
Section (64-bit Windows OS) HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\SolarWinds\CatTools\Properties
Value (STRING) NTServiceSocket
Min. value 1
Max value 65535
Default value 4400
Type TCP port number
