Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools TFTP pane
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The TFTP pane enables you to view messages originating from the CatTools TFTP server. You can also stop or start the TFTP server from this tab.
Option Description
Start
Starts the TFTP server, if it is not already started.
Stop
Stops the TFTP server if it is running.
Clear TFTP
Clears the display of TFTP server messages.
