Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Display pane
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Display pane shows the current message displayed by each of the various tasks and clients associated with CatTools.
  • The Thread column identifies the originating task, which may be the main CatTools task or one of the clients.
  • The Device column identifies the device currently linked to the task.
  • The Status column shows the latest message from the task.
Option Description
Clear Display
Clears the Display pane of any messages.
