Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Compare pane
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
This pane enables you to create a comparison report of two files of your choice. The report is the same format as that created by the Device.Backup.Running Config activity when changes are detected.
Option Description
Save activities
Saves the comparison data displayed to a disk file.
Clear activities
Clears the display of comparison report information.
Select activities
Displays a dialogue that allows you to select the two files to compare.
