Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools View menu
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The View menu allows you to review CatTools data files using the notepad editor.
Menu option Description
Reports folder
View the Reports folder using Windows Explorer.
The reports from scheduled activities are stored in the \Reports sub folder. Clicking on this menu opens Windows Explorer to the reports sub folder so you can browse the contents.
You can view the reports with MS-Excel, Log Viewer or use the internal viewer in CatTools from the Reports tab.
Captured Data folder
View captured data using Windows Explorer.
The data captured from scheduled activities is stored in the \Captured Data sub folder. Clicking on this menu will open Windows explorer to the Reports sub folder so you can browse the contents.
Configs folder
View the configs folder using Windows Explorer.
The device configurations from the Device.Backup.Running Config configuration activity are stored in the \Configs sub folder. Clicking on this menu opens Windows Explorer to the Configs sub folder so you can browse the contents.
You can view the configs with Notepad or Wordpad etc.
Email log
View CatTools email activity log file using Notepad.
Activity log
View CatTools activity summary log file using Notepad.
Info log
View CatTools info log file using Notepad.
