Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Kiwi CatTools Interface menu
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
The Interface menu allows you to change the Panes and Themes interface options in Kiwi CatTools.
Menu option Description
Interface Panes
There are a number of options under Interface > Panes:
  • Turn panes on and off by selecting or deselecting them from the panes list.
  • Save your current pane layout by clicking the Save user defined layout menu item.
    CatTools automatically saves your current pane layout when you exit the application.
  • Restore your previously saved pane layout by clicking Restore user defined layout.
  • Restore the CatTools default pane layout by selecting Restore to default layout.
Themes
Change the theme of CatTools by clicking the Interface|Themes menu item and selecting an option from the list of themes.
