Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Main script - ct. variables and functions
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Below is a list of CatTools application 'ct.' variables, functions and sub routines, with some examples of how to implement them in your custom activity main script files. This is not a full set of all the internal ct. variables and functions used within the CatTools application, however it contains details of those from within the main script template files, plus a few additional ones which may be useful when creating your custom activity main scripts.
Variables
ct.ScheduleNumber The current schedule number.
ct.Devices A pipe (|) delimited string of devices to connect to (i.e. the devices associated with the current schedule).
ct.ScriptFileClient
A string variable to store the file name of the client script file that is used by the activity.
ct.QuitNow
A variable that is checked in a number of places within an activity to stop it running. For example, it is set to 1 when the 'STOP' button is pressed while an activity is running. This variable can only be referenced from within an activity Main Script. Use the cl.QuitNow client variable is referencing within the Client Scripts.
Functions and Sub routines - Summary list
General and File
ct.Log Sends a line of text to the Infolog.txt file and Info Log pane
ct.ReadFromFile Read in contents of a given file
ct.ReplaceFilenameVariables Replace filename variables in report filenames to real text values.
ct.CreateMasterTable Creates a master table file.
ct.CreateAndSendReport Creates report files (.txt .html, etc.) and sends by email.
ct.RemoveClientResults
Removes existing client temporary .txt files within the \ClientTemp folder.
Activity
ct.MarshalThreads
Manages the client threads used within the activity schedule.
ct.DBScheduleGetField
Get activity field value from the CatTools database.
Device
ct.RemoveHeader
Removes the first line of data from within a data block.
Functions and Sub routines- Details and examples
The functions and sub routines listed in the above table are further detailed below with their input parameters and examples of their usage are provided.
ct.Log(sDevice, iPriority, sMessage)
This sub routine sends a line of text to the Infolog.txt file and Info Log pane. It has three input parameters:
sDevice The name of the device as a string. If an empty string, or VBNullString, then the string value is "CatTools" referring to an internal application related log message rather than a device specific message.
iPriority
Integer range 1 to 4 representing the logging 'level' for the line being sent.
  • 1 = Error
  • 2 = Warning
  • 3 = Information
  • 4 = Debug
sMessage Message text of the line being sent.
Example
Log a level 1 (error) message for CatTools, rather than any specific device, such as sDevice= "", with the text "No devices have been selected".
ct.Log "", 1, "No devices have been selected"
ct.ReadFromFile(sFileName) As String
This function is used to read in the contents of a given file. The function returns a string of the file data. It performs the same operation as the client function cl.ReadFromFile, but can only be called from within an activity Main Script. It has one input parameter:
sFileName
String of the filename and path of the file to read in the contents of.
Example
Read in the contents of a file called "ReportData", removing the first row header row.
Dim sReportFile
Dim sReportData
' Get the file name and path from the activity settings and replace any filename variables.
sReportFile = ct.DBScheduleGetField(ct.ScheduleNumber, "ReportFile")
sReportFile = ct.ReplaceFilenameVariables("", ReportFile)
' Read the contents of the report file, remove the first line of data (header row) and save the results to sReportData variable.
sReportData = ct.RemoveHeader(ct.ReadFromFile(sReportFile))
ct.ReplaceFilenameVariables(sDeviceName, sFileName) As String
This function is used to replace any filename variables in the report filename to the actual text values. It returns the modified string with the filename variables replaced. It has two input parameters:
sDeviceName String value for the device name. Set sDeviceName to be an empty string ("") when you are translating an activity Report file name, as these should not contain device specific filename variables.
sFileName
String of the filename and path of the file being checked.
Example
Get the report filename for an activity and perform any filename variable replacements, then store the value in a string variable.
sReportFile = ct.ReplaceFilenameVariables("", sReportFile)
ct.CreateMasterTable(sReportFile, sHeader, bOverwrite, sDeviceList, sClientFilePrefix, sTableFormat) As Boolean
This function is used to create the master table file. If successful, it returns a value of True, else if not then returns False. It has six input parameters:
sReportFile
String value of the report/master table file name and path to create
sHeader
Tab delimited string for the report header as defined in the activity Main Script.
bOverwrite
Boolean value. If 0 (False) the file will be appended to, otherwise it is overwritten.
sDeviceList
Pipe (|) delimited string of devices associated with the current schedule (use the "ct.Devices" variable)
sClientFilePrefix
File name prefix string for the temporary client (device) files that the activity creates in \ClientTemp in order to consolidate for the Master table file.
sTableFormat Pipe (|) delimited string used for those activities where you can modify the table definition output (change column names; include/exclude columns from the output; and change the table column order: For example, the Options tab of the Report.SNMP.System Summary activity).
Example
Create the master table for a version report. Get the Report file name and Overwrite values from the activity settings in the database; and define the report header. Use a prefix of "CustomReportTemplate" for each temporary client (device) file.
Dim sReportFile
Dim bOverwrite
Dim sHeader
bOverwrite = ct.DBScheduleGetField(ct.ScheduleNumber, "ReportOverwrite")
sHeader = "Group" & vbTab & "Device Name" & vbTab & "IP Address" & vbTab & "Serial #" & vbTab & _"Processor" &
vbTab & "IOS" & vbTab & "Uptime"
' Create the master table
bRetVal = ct.CreateMasterTable(sReportFile, sHeader, bOverwrite, ct.Devices, "CustomReportTemplate", "")
ct.CreateAndSendReport(sScheduleName, sHeader, sData, sReportFile)
This sub routine is used to create the report files (.txt .html, etc.) and if the relevant options are set, it will also send the reports by email. It has four input parameters:
sScheduleName The schedule name used for the report title, and email message subject title.
sHeader Tab delimited string for the report header as defined in the activity Main Script.
sData String of the report data.
sReportFile String value of the report file name and path to create.
Example
Create a simple version report. Get the Activity name and Report file name from the activity settings in the database; and define the report header.
Dim sClientFile
Dim sScheduleName
Dim bOverwrite
Dim sReportFile
Dim sHeader
' Prefix for temporary client file filenames
sClientFile = "CustomReportTemplate"
' Get the schedule name from the activity settings
sScheduleName = ct.DBScheduleGetField(ct.ScheduleNumber, "Name")
' Get overwrite option value
' Get report file name
' Define the report header
Call ct.CreateMasterTable(sReportFile, sHeader, bOverwrite, ct.Devices, sClientFile, "")
' Call CatTools function to create and send the report
Call ct.CreateAndSendReport(sScheduleName & " (Custom Template Report)", sHeader,ct.RemoveHeader
(ct.ReadFromFile(sReportFile)), sReportFile)
' Finally, clean up by deleting any temp client files
Call ct.RemoveClientResults(sClientFile)
This sub routine removes any existing client temporary .txt files within the \ClientTemp folder, with a filename beginning with the string value of sClientFile. It has one input parameter:
sClientFile
String value of the file names to find.
ct.MarshalThreads(ByVal sDeviceList As String, ByVal sScriptFile As String, ByValsFunctionName As String, ByVal lMaxProcessCount As Long, ByVal sUniqueFileID AsString)
This sub routine manages the client threads used within the activity schedule. It has five input parameters:
sDeviceList
Pipe (|) delimited string of devices associated with the current schedule (use the "ct.Devices" variable for this parameter).
sScriptFile
String of the filename of client script file to use (specify the "ct.ScriptFileClient" variable for this parameter).
sFunctionName String of the Function name within the client script file to use (normally this should be "Client").
lMaxProcessCount
Maximum number of client threads to use for the activity (this will be automatically restricted by your Edition of CatTools).
sUniqueFileID File name prefix string for the temporary client (device) files that the activity creates in \ClientTemp within the activity.
Example
Start the client threads for a simple version report. Get the maximum client threads from the activity settings in the database.
Dim lMaxClientThreads
' Get the number of client threads from the activity settings
lMaxClientThreads = ct.DBScheduleGetField(ct.ScheduleNumber, "ClientThreads")
' Start the threads
Call ct.MarshalThreads(ct.Devices, ct.ScriptFileClient, "Client", lMaxClientThreads, "CustomReportTemplate")
ct.DBScheduleGetField(lScheduleNumber, sFieldName)
This function is used to get a field value from the CatTools database for a given activity. It performs the same operation as the client function cl.DBScheduleGetField, but can only be called from within an activity Main Script. It has two input parameters:
lScheduleNumber
The current schedule number as a Long.
sFieldName
The field name in the database we want to get the value of as a String.
Example
Get the report filename for an activity and store the value is the string variable sReportFile.
ct.RemoveHeader(sData) As String
This function is used to remove the first line of data in a given block of data. It does so by locating the first instance of a vbCrLf, and removes everything up to and including it. The function returns a string with the first data line removed. It has one input parameter:
sData
String of the data to manipulate.
