Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Export devices to tab delimited file
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Export your device information to a tab-delimited file, suitable for reporting using tools like MS-Excel or similar.
  1. Go to File > CatTools database, and then click Export.
  2. Export devices to tab-delimited file.
  3. In the file selection box, browse to select the folder to create the export file in.
  4. Enter the name of the device export.
  5. A dialog will prompt you to generate an encryption password for the database backup. Create a password and click OK.
  6. It is critical to remember the password you create. Without the password, your data will be lost and cannot be retrieved.
