Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Export activities to tab delimited file
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Export your activity data to a tab-delimited file, suitable for reporting using tools like MS-Excel or similar:
  1. Go to File > CatTools database, and then click Export.
  2. Export activities to tab delimited file.
  3. In the file selection box, browse to select the folder to create the exported file in.
  4. Enter the name of the activities export.
