Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Enable capture mode
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
Capture mode can be used to help diagnose device connection or device activity problems.
If an activity is failing for an unknown reason, technical support may ask you to Enable capture mode before attempting to run the activity. This captures all the interaction between CatTools and the device to a log file. This file can then be sent to technical support to assist in troubleshooting the problem.
Enable capture mode functions like a tick box and by default is unselected. To enable this option:
  1. Go to File and click Enable capture mode.
  2. Capture mode is immediately enabled, as indicated by the check mark.
    Clicking this option again disables capture mode.
  3. Captured data is stored in the \Debug sub-folder. The file name is dependent on the name of the captured device.
    For example, a device called 2950 running on client thread 1 creates the file: DebugLog-1-2950.txt
Device captures can be included when creating the diagnostics file for Technical Support.
