Documentation forKiwi CatTools (3.12.7 and earlier)
Try the next generation of Kiwi CatTools and take advantage of a refreshed interface and improved performance, security, and maintainability.
Edit a device on the Kiwi CatTools database
This topic applies to KCT 3.12.7 and earlier. If you are on KCT NG 2026.2 or later, see NG topic.
To edit a network device that has been added in Kiwi CatTools, select a device on the Devices Pane and click Edit.
The Device Information window opens, with the same tags and options available as with adding a new device.
The existing configurations for the device are selected. Once you've made the changes to your device, test the configuration by clicking Ping Device. If the test returns successful, click OK.
