Documentation foripMonitor
Mass edit monitor properties
Use the Mass Edit feature to apply large-scale changes to configuration fields across any number of monitors using a rule-based system.
Using this feature, you can:
  • Add a prefix string (such as an IP address or machine name) to monitor names
  • Change the timing parameters of all monitors, or only of monitors in a filtered subset
  • Quickly update the configuration settings of monitors created using the Network Scan
  • Enable or disable monitor statistics
To mass edit the monitor properties in two or more monitors:
  1. Click Devices in the toolbar.
  2. In the My Network toolbar, click Edit > Mass Edit > Monitor Properties.
  3. Complete the wizard.
