Documentation forIpMonitor
Effective December 31, 2024, IpMonitor will reach its end of life and will no longer be available or supported. If you liked IpMonitor, consider trying another SolarWinds product.
Configure ipMonitor to listen for HTTPS traffic
After you install an SSL certificate from a Certificate Authority (CA) or generate a self-signed certificate, configure ipMonitor to listen for HTTPS traffic in your network.
  1. In the configuration program window, click Communications: Web Server Ports.
  2. Click Add.
  3. In the IP Address field, enter an IP address or enter 0.0.0.0 to enable ipMonitor to listen on all available IP addresses.
  4. In the Port (TCP) field, enter 443 (default) for HTTPS communications.
  5. Select the Enable SSL checkbox.
  6. Click OK.
    ipMonitor begins listening on the new SSL IP and port combination.
