Edit Subnet Properties Window
This page allows you to edit your subnet property name, CIDR, description, VLAN ID, Location.
- Automatic Scanning: Check Disable Automatic Scanning if you do not want IPAM to continuously scan the subnet. The scan interval can be adjusted to a range of 10 minutes to 7 days.
- Data Retention: Check Discard IP Addresses that haven't responded to select a time frame between 1 and 30 days.
