Sysdig Monitor
Sysdig Monitor is a monitoring tool you need to gain visibility into the infrastructure, applications, and services that drive your business. Get results quickly with out-of-the-box Kubernetes infrastructure visualizations, cloud integrations, dashboards, and alerts.
Route detailed events from Sysdig Monitor to the right users in Incident Response.
How to integrate Sysdig Monitor with Incident Response
In Incident Response: Using Sysdig Monitor as an Alert Source
  2. How to configure Sysdig Monitor integration in Squadcast
  3. Select Sysdig Monitor. Copy the displayed Webhook URL to configure it within Sysdig Monitor. Finish by clicking Add Alert Source -> Done.
Steps to add Sysdig Monitor integration to a service in Squadcast
When an alert source turns Active, it’ll show up under Configured Alert Sources. You can either generate a test alert from the integration or wait for a real-time alert to be generated by the Alert Source.
An Alert Source is active if there is a recorded incident via that Alert Source for the Service.
In Sysdig Monitor: Add a Notification Channel for Incident Response
Note:
You can add a Notification Channel in Sysdig Monitor only if your user has the right permissions. More information on this is available here.
  1. Click on your username in the bottom left corner and select Settings
  2. Select Notification Channels from the sidebar
  3. Select Add Notification Channel and select Webhook
  4. To create a Incident Response Webhook Notification Channel:
  • URL: Paste the previously copied Webhook URL from Incident Response
  • Channel Name: Give the Channel a meaningful Name
  • Enabled: Toggle on
  • Notify when Resolved: Toggle on
  • Notify when Acknowledged: Toggle off
  • Test notification: Toggle on
  • Click Save to save the Incident Response Webhook Notification Channel
  1. Verify that the Webhook that you added is visible in Notification Channels and is Enabled
Note:
When you save the Webhook, a test alert is sent to Incident Response for which Incident Response creates a test incident. This will verify that the Webhook is working as expected.
That is it, you are now good to go!
  • Now whenever an alert is triggered in Sysdig Monitor, an incident will be created for it in Incident Response.
  • Once the alert(s) that triggered the incident(s) are resolved in Sysdig Monitor, the corresponding Incident Response incidents would get resolved automatically.
