Dotcom Monitor
Dotcom Monitor monitors performance, functionality, and uptime from real browsers to accurately understand how your web pages, web applications, APIs, and services are performing for users in real time.
Route detailed monitoring alerts from Dotcom Monitor to the right users in Incident Response.
How to integrate Dotcom Monitor with Incident Response
In Incident Response: Using Dotcom Monitor as an Alert Source
Navigate to Services -> Service Overview -> select or search for your Service. Expand the accordion -> In the Alert Sources section, click Add.
Select Dotcom Monitor. Copy the displayed Webhook URL to configure it within Dotcom Monitor. Finish by clicking Add Alert Source -> Done.
When an alert source turns Active, it’ll show up under Configured Alert Sources. You can either generate a test alert from the integration or wait for a real-time alert to be generated by the Alert Source.
An Alert Source is active if there is a recorded incident via that Alert Source for the Service.
In Dotcom Monitor: Create a Incident Response Webhook
From your home page, click on the Configure > Notification Groups and New Group
Provide Group Name and click on New Address button
Select HTTP Webhook, paste previously copied webhook URL into Webhook URL field and select Request Type as Post
In Post Data section, select Data Type as
Raw, Content Type asJsonand click on expand icon in Body field -
Select Json, paste below in textbox and click on Done
"devicename" : "@Model.Site_Name",
"taskName" : "@Model.FirstErrorResponse.Task.Name",
@if (@Model.FirstErrorResponse.AllErrors != null){
<text>
"error" : {
"ErrorType":"@Model.FirstErrorResponse.AllErrors[0].ErrorType",
"ErrorCode":"@Model.FirstErrorResponse.AllErrors[0].ErrorCode",
"Reason":"@Model.FirstErrorResponse.AllErrors[0].Reason"
"Status": "Error",
</text>
@if (@Model.FirstErrorResponse.AllErrors == null) {
<text>
"Status":"Ok",
</text>
"StartMonitorDowntime" : "@Model.StartMonitorDowntime",
"MonitorName": "@Model.RootResponse.Monitor.Name",
"MonitoringTime": "@Model.Monitor_DateTime",
"PlatformType": "@Model.RootResponse.Device.PlatformType",
"DeviceReportingUrl": "@Model.OnlineReportLink?CUID=@Model.OnlineReportCUID"
Configuring Alerts for Device
Within the Device Manager tab, edit existing device or add new device. Under Alert tab click on Add Group button, select Incident Response Notification and click on Apply
check both False Positive Check, Send Uptime Alert and click on Save And Close
Now, every time there is an alert for your device in Dotcom Monitor, the alert will be sent to Incident Response and an incident will be triggered. Similarly, if the alert gets resolved within Dotcom Monitor, it will get auto-resolved in Incident Response as well.
That is it, your integration is complete and you are good to go!
