Azure Monitor
Follow the steps below to configure a service so as to extract its related alert data from Azure monitor.
Incident Response will then process this information to create incidents for this service as per your preferences.
Using Azure Monitor as an Alert Source
  2. How to configure Azure Monitor integration in Squadcast
  3. Select Azure Monitor. Copy the displayed Webhook URL to configure it within Azure Monitor. Finish by clicking Add Alert Source -> Done.
Steps to add Azure Monitor integration to a service in Squadcast
When an alert source turns Active, it’ll show up under Configured Alert Sources. You can either generate a test alert from the integration or wait for a real-time alert to be generated by the Alert Source.
An Alert Source is active if there is a recorded incident via that Alert Source for the Service.
Create Incident Response Webhook in Azure
Login to your Azure account select your virtual machine. Under Monitoring, go to Alerts.
Then go to Manage Actions → Add Action groups → Creatre action group (Test grp or Incident Response webhook alerts) by selecting Action type as Webhook. Paste the squadcast webhook url from the previous step and make sure Enable the common alert schema toggle switch is turned on.
Creating Squadcast Webhook in Azure: Configure webhook action group with Squadcast URL in Azure Alerts under Monitoring for virtual machine
Go back to Alerts window and click New Alert. Specify Resource, Condition and under Actions select the action group (Test grp or Incident Response webhook alerts) you just made. Provide alert rule Name, Description and Create Alert.
Creating Azure Alert with Squadcast Webhook: Specify resource, condition, and select the action group. Provide name, description, and create the alert
Now whenever an alert is triggered by Azure Monitor, an incident will be created automatically in Incident Response.
The Azure Monitor integration comes with an Auto-Resolve feature, meaning that whenever the alerts gets resolved in Azure, the incident will automatically get resolved in Incident Response as well.
