MIB Viewer tool
The MIB Viewer tool in ETS for the Desktop queries the management information base (MIB) database to display any OID or table. It provides a faster method than the SNMP MIB Browser to retrieve frequently used MIBs, but it does not provide browsing of the MIB tree.
See the following sections:
Open the MIB Viewer tool
To launch the tool from the Toolset Launch Pad, locate the MIB Viewer tool and click Launch.
You can add the tool to a tab in the Workspace Studio, and access it from there.
To launch the tool from the Windows Start menu:
Click Start > All > SolarWinds Engineer's Toolset.
Right-click MIB Viewer, click More, and click Run as administrator.
View an OID or a table
Enter the host name or IP address of the target device.
MIB Viewer directly queries the device for supported MIBs.
Provide an SNMP community string.
To modify values, ensure you provide the read and write community string.
Provide an OID or table name or enter an entire MIB tree.
The MIB Viewer tool analyzes your input and determines the best way to format the results. You can also concatenate MIBs by placing an ampersand '&' between them. The MIB Viewer downloads each OID and MIB tree in the order you enter them. See Guidelines and examples.
OID values in blue are read and write and can be changed, if you supplied a read and write community string. Click the value and enter a new value, or use the list to select a value.
To view details about a selected OID, including the numerical OID and description, click View > Details.
Review the following table for examples of valid input for the MIB Table to download field.
MIB Table to download field |
Description |
RFC1213-MIB:system |
MIB-II system tree |
1.3.6.1.2.1.1 |
Numeric OID equivalent to RFC1213-MIB:system |
hrSWRunTable |
Running software from the Host-Resources MIB |
ipInReceives & next 16 |
IP Statistics |
ICMP |
ICMP statistics from RFC-1213 |
tcpRtoAlgorithm & Next 11 & tcpInErrs & tcpOutRsts |
TCP Statistics |
etherStatsTable |
RMON Ethernet Statistics |
frCircuitTable |
Frame Relay circuits |
bgpPeerTable |
BGP peer table |
ifPhysAddress |
MAC addresses for all interfaces on a device |
hrSWInstalledTable |
Installed software |
OLD-CISCO-MEMORY-MIB:freeMem & Next 39 & bufferHgSize & Next 7 |
Cisco Buffers |
cdpCacheTable |
Cisco Discovery Protocol table |
tcpConnTable |
TCP connection table |
You can add
Next X, where X represents the number of OIDs to return. The Cisco Buffers in the previous table of examples provides an example of the Next X syntax. -
Each OID can be fully qualified with the MIB Name, a colon, and the OID name. Or you can provide only the MIB tree.
For common OID names that could exist in multiple MIBs, include the MIB Name when specifying the value. For example, system exists in RFC1213-MIB, HP-UNIX, INTEL-GEN-MIB, and the Apple Macintosh MIB, therefore specify the MIB when retrieving the value: RFC1213-MIB:system or HP-UNIX:system or INTEL-GEN-MIB:system.
Valid formats for the OID name are provided in the following table:
MIBName:OIDName |
OLD-CISCO-MEMORY-MIB:freeMem |
Numeric OID |
1.3.6.1.2.1.1 |
1.3.6.1.4.1.9.9.27.1.1.2 |
OIDName |
tcpConnTable |
cdpCacheTable |
Export, print, and copy values
After retrieving MIB values, MIB Viewer can transfer that information to other tools by exporting to a different file format or by copying and pasting as text. You can also print the discovered information.
Export values
- Click File > Export, and then select the type of export.
- Select the information to export.
- Name the path for the exported information.
Copy values as plain text
To copy some of the information:
Select the cells.
Click Edit > Copy Selection.
To copy all information, click Edit > Copy All.
Print values
Click File > Print, and then select the information to print.
