Integrate SRM and SRM Profiler
If you have both SolarWinds SRM and SRM Profiler installed, you can integrate them as follows.
- From the SolarWinds Platform Web Console, navigate to Settings > All Settings.
- Click SRM Settings in the Product Specific Settings section.
- Click Manage SRM Profiler Module Integration in the License Summary section.
The Setup SRM Profiler Module Integration page opens.
- Enter the requested information for the Profiler module.
- Click Test Connection to verify your settings, and then click Submit.
If the test fails, verify your credentials and connectivity to the SRM Profiler module server.
