Documentation forIP Address Manager
Managing IP addresses is a key capability of SolarWinds Observability Self-Hosted (formerly Hybrid Cloud Observability) and is available in the Essentials edition. IP Address Manager (IPAM) is also available in a standalone module.
The IPAM DHCP & DNS Management (Legacy) view
The legacy IPAM DHCP & DNS Management page allows you to navigate through tabs to manage your DNS and DHCP servers.
To toggle between new and legacy versions of the DHCP & DNS Management page, see Switch between versions.
The DHCP & DNS Management page is divided into two panes.
The left pane can be used to group and select the items displayed by catagories.
The right pane provides three tabs, providing the following views:
  • DHCP tab
  • DNS Zones tab
  • DNS Servers tab
The columns in the DHCP, DNS Zones and DNS Servers views can be hidden or displayed by moving the cursor over any column heading, clicking on the down arrow that appears, selecting Add/Remove Columns, and selecting or deselecting the appropriate item. You can also drag and drop the columns into the order required in the DNS Zones and DNS Servers views. These changes will be retained for your login.
DHCP tab
The DHCP Servers tab displays a list of all DHCP Servers that are monitored in IPAM. These can be grouped by server type, VLAD ID, server location or status, or by Scopes name or status.
For information on adding and editing DHCP servers, see Monitor and manage DHCP servers.
  • Click the icon before a Server to display the scopes on this server.
  • Click a scope to open the IP Address View details.
DNS Zones tab
The DNS Zones tab displays all monitored DNS Zones. These can be grouped by zones by server or status, or servers by status or server type.
For information on DNS zones, see Add a DNS zone and Edit a DNS zone.
DNS Servers Tab
The DNS Servers tab displays all monitored DNS Servers. These can be grouped by zones by server or status, or servers by status or server type.
For information on adding and editing DNS servers, see Monitor and manage DNS servers.
  • Click a server to display the DNS Zones tab, grouped by Server.
