Configure DPA to use credentials stored in CyberArk
DPA can use credentials stored in CyberArk for authentication to:
- The DPA repository
- Monitored database instances
- Monitored VMware ESX/ESXi Hosts or vCenter Servers
- LDAP/AD servers
- Mail servers
You can configure DPA to use CyberArk credentials globally, for authentication to all of the entities listed above. Or you can configure DPA to use CyberArk credentials for certain types of authentication. For example, DPA could use CyberArk credentials for authentication to the DPA repository and monitored instances, but not to VMware, LDAP/AD, or mail servers.
DPA uses the REST API to call the CyberArk Central Credential Provider (CCP) and client certificates authentication to authenticate to it, which means that your CyberArk CCP must be configured to use SSL.
Complete the following tasks to configure DPA to use CyberArk to as a credential provider:
Gather the required information
To configure CyberArk integration in DPA, you must have the following information:
- The URL of the CyberArk Central Credential Provider
- The client certificate that will be used to authenticate to the CyberArk CCP
- The CA root certificate of CyberArk CCP server if you are using a private Certification Authority to create trust between DPA and CyberArk CCP
If your client certificate is in PEM format, convert it to PKCS12 format
DPA does not support PEM format. If your client certificate is in PEM format, complete the following steps to convert it to PKCS12 format.
- Download and install the OpenSSL toolkit. For Windows you can download it from here.
Open a command prompt and run the following command, where
yourClientCertificate.pemis your client certificate file in PEM format.openssl pkcs12 -export -inkey yourClientCertificate.pem -in yourClientCertificate.pem -out CA_keystore.p12 -
When prompted, enter the password protecting the PEM file (if there is one).
When prompted, set a password for the new PKCS12 file. This is the password you will use for the
keystore.passwordandkey.passwordproperties in thecyberark.propertiesfile.OpenSSL uses the same password for both the keystore and the key itself.
A new file called CA_keystore.p12 is created. It stores the converted client certificate in PKCS12 format. Specify this file as the keystore.location property in the cyberark.properties file.
Configure the cyberark.properties file
Open the following file in a text editor:
DPA-install-dir\iwc\tomcat\ignite_config\idc\cyberark.properties - Enter the values for the following properties, and save the file.
base.uri
The common part of requests to get credentials from the CyberArk CCP. All requests made by DPA to the CCP consist of this URL concatenated with a suffix specific to the given connection. For example, if your CCP URL is https://cyberark.prod.com and your AppID for DPA is DPA, the base.uri is specified as:
base.uri=https://cyberark.prod.com/AIMWebService/api/Accounts?AppID=DPA
When you register database instances for monitoring (for example), you will use the suffix query that is specific to the monitored instance. This type of query might look like this:
&safe=mondb&object=sqlserverprod1
In this example, DPA would use the following URL to get the credentials for this monitored instance:
https://cyberark.prod.com/AIMWebService/api/Accounts?AppID=DPA&safe=mondb&object=sqlserverprod1
DPA provides flexibility for structuring your CCP requests. You can use any field documented by CyberArk.
request.timeout.millis
The connection timeout of the CCP requests in milliseconds. If this value is not specified, the default value of 30000 (30 seconds) is used. If you are using the ConnectionTimeout property as part of the CCP URL, the lower value of the two properties is used.
disable.hostname.verification
Disables hostname verification. If set to true, DPA does not verify that the CyberArk CCP server certificate matches the CyberArk CCP hostname. DPA recommends the default of false (hostname verification is enabled).
keystore.location
The path to the keystore that holds your client certificate used to authenticate DPA requests to the CyberArk CCP. Be aware that if your location string contains a backslash (\) you must escape it with another backslash, as shown in the following example:
keystore.location= C:\\security\\ca_keystore.p12
keystore.type
The type of keystore. Valid values are jks and pkcs12.
DPA supports the following file types:
- PKCS12: The file usually has a
.p12extension.- JKS: The file usually has a
.jksextension.
If your file is in a different format, take one of the following actions:
- PEM: If your client certificate is in PEM format, convert it to PKCS12 format.
- PXF: A file in PXF format can be used as-is, because the PXF and PKCS12 formats are generally interchangeable. Enter
pkcs12as thekeystore.type.
keystore.password
The password to the keystore. After DPA starts, this value is encrypted based on the settings specified in DPA password encryption settings.
key.password
The password to the client certificate in the keystore. After DPA starts, this value is encrypted based on the settings specified in DPA password encryption settings.
Establish trust between DPA, the CyberArk CCP, and the client certificate
Because your CyberArk deployment is using SSL, you must ensure that DPA is configured to trust the CyberArk CCP server certificate. To do this, import the CA certificate of the CyberArk CCP into the DPA trust store.
Enable auto-invalidation of monitored instance connections when credentials have changed
DPA polls credentials from CyberArk every 10 minutes (by default). If new credentials are detected, all connections created after the change will respect the new credentials.
If CyberArk stops providing the credentials (for example, because the account name in CyberArk changed so the query is no longer valid, or CyberArk is down for some reason), DPA will postpone the connection invalidations to help you overcome short CyberArk outages. By default, the delay in connection invalidations is 30 minutes. You can configure this value for every connection type by setting following properties in the system.properties file, with the value in minutes:
For the repository connection:
com.solarwinds.dpa.cyberark.checker.repo.periodicClearCredentialsMinutes=30 -
For monitored database instance connections:
com.solarwinds.dpa.cyberark.checker.periodicClearCredentialsMinutes=30 -
For monitored VMware ESX/ESXi Host or vCenter Server connections:
com.solarwinds.dpa.cyberark.checker.vsphere.periodicClearCredentialsMinutes=30 -
For an LDAP/AD server connection:
com.solarwinds.dpa.cyberark.checker.ldap.periodicClearCredentialsMinutes=30 -
For a mail server connection:
com.solarwinds.dpa.cyberark.checker.mail.periodicClearCredentialsMinutes=30
A value of 30 minutes means that DPA will invalidate existing connections if CyberArk is not able to provide credentials for a period longer than 30 minutes.
To reschedule the DPA credentials polling job (which runs every 10 minutes by default), set the following properties in the system.properties file, with the value in milliseconds:
com.solarwinds.dpa.cyberark.checker.repo.periodicIntervalMillis=600000 -
com.solarwinds.dpa.cyberark.checker.periodicIntervalMillis=600000 -
com.solarwinds.dpa.cyberark.checker.vsphere.periodicIntervalMillis=600000 -
com.solarwinds.dpa.cyberark.checker.ldap.periodicIntervalMillis=600000 -
com.solarwinds.dpa.cyberark.checker.mail.periodicIntervalMillis=600000
Enter connection credentials into CyberArk and test them
Add all connection credentials used by DPA into CyberArk. SolarWinds recommends using the DPA REST API to test the connection queries before you enable the integration.
Enable the DPA CyberArk integration
After you have edited the cyberark.properties file and updated the DPA trust store with the required certificates, complete the following steps to enable CyberArk mode so that DPA will start to use those settings.
DPA-install-dir\iwc\tomcat\ignite_config\idc\system.properties -
Uncomment or add one of the following, and save the file:
If all credentials that DPA uses for authentication are stored in CyberArk, uncomment or add the following line:
com.solarwinds.dpa.credentials.provider.type=CYBERARK_REMOTEThe general property
com.solarwinds.dpa.credentials.provider.typeis the default and includes all credential types. If you include bothcom.solarwinds.dpa.credentials.provider.typeand one or more of the type-specific properties listed below, the value for the type-specific property takes precedence. -
If only some of the credentials that DPA uses are stored in CyberArk, uncomment or add the following lines as needed. Enter a value of either
DPAorCYBERARK_REMOTEto specify where the credentials are stored:com.solarwinds.dpa.credentials.provider.type.database = [DPA || CYBERARK_REMOTE]com.solarwinds.dpa.credentials.provider.type.repository = [DPA || CYBERARK_REMOTE]com.solarwinds.dpa.credentials.provider.type.vsphere = [DPA || CYBERARK_REMOTE]com.solarwinds.dpa.credentials.provider.type.mail = [DPA || CYBERARK_REMOTE]com.solarwinds.dpa.credentials.provider.type.ldap = [DPA || CYBERARK_REMOTE]
After the restart, the affected DPA wizards and other interfaces display a field for the CyberArk credentials query instead of the user name and password fields.
Update an existing DPA installation to use credentials stored in CyberArk
If any of the following were configured before the CyberArk integration, you must update the configurations to use credentials stored in CyberArk:
- The DPA repository database
- AD or LDAP server
- Your company mail server that is used to send emails from DPA
For new installations without a repository database, see Create a DPA repository that uses CyberArk for authentication.
- To configure the DPA repository database to use credentials stored in CyberArk:
DPA-install-dir\iwc\tomcat\ignite_config\idc\repo.propertiesRemove the
repo.userandrepo.passwordproperties.Add the following setting, where
cyberArkQueryForRepoCredentialsis the CyberArk query that DPA will use to obtain the credentials to connect to the repository database:repo.cyberarkQuery=cyberArkQueryForRepoCredentialsFor example:
repo.cyberarkQuery=&safe=mondb&object=dparepoSave the file.
Restart DPA for the changes to take effect.
- For each monitored database instance, use the Update Connection Wizard to enter the CyberArk credentials query. Or use the cyberArkQuery parameter in the DPA REST API to update existing monitored database instances.
- For each monitored VMware ESX/ESXi Host or vCenter Server, open the Update VMware Connection page and enter the CyberArk credentials query.
If DPA uses your company's mail server to send email, update the mail server configuration and enter the CyberArk credentials query.
If DPA uses the default mail server or the embedded mail server, no changes are needed.
- If DPA is configured to use AD or LDAP user authentication, use the Configure AD/LDAP wizard to enter the CyberArk credentials query. Then restart DPA for the changes to take effect.
Register additional database instances for monitoring
When DPA is started in CyberArk mode, you must specify the CyberArk query instead of entering a user name and password when you register monitored database instances. You can use the Register Database Instance wizard, mass registration, or the REST API to register instances:
To use the Register Database Instance wizard, follow the instructions in one of the following topics for creating the monitoring user and completing the wizard:
- Register an Oracle database instance
- Register a SQL Server database instance
- Register a Sybase database instance
- Register a Db2 database instance
- Register a MySQL, Percona, or Maria database instance
- Register a PostgreSQL database instance and prepare for monitoring
- Register an Amazon RDS for Oracle database instance
- Register an Amazon RDS for SQL Server database instance
- Register an Amazon RDS for MySQL or MySQL-compatible Aurora database instance
- Register an Azure SQL database
- Register an Azure SQL Managed Instance
To use mass registration or the REST API:
Follow the instructions in one of the topics listed above to create the monitoring user.
Access the REST API, or open the Mass registration page and choose All database types.
See the following table for API parameters or registration file template values.
If you use mass registration or the REST API, enter the required values in the mass registration form or in the REST API call. Values specific to CyberArk implementation are described in the following table.
| Mass registration field | REST API parameter | Value |
Monitoring User Monitoring User Password Privileged User Privileged User Password SYS Password |
monitoringUser monitoringUserPassword sysAdminUser sysAdminPassword sysPassword |
Do not enter a value. |
| CyberArk query | cyberArkQuery |
Enter information that can be concatenated with the
DPA will use values in the UserName and Content fields from the CyberArk response as credentials for monitoring the database. DPA does not use the Domain field in the CyberArk object. If a domain needs to be specified during authentication, the value in the UserName field must be in the format |
| Create Monitoring User | monitoringUserIsNew |
Enter Enter |
The following example shows a REST API request to register Oracle instance:
{ "databaseType": "ORACLE",
"serverName": "127.0.0.1",
"serviceNameOrSID": "DPA_ORA11R1",
"port": "1521",
"monitoringUserIsNew": false,
"displayName": "DPA_ORA11R1",
"cyberArkQuery: "&safe=mondb&object=oracleprod1"
Secure your CyberArk integration
SolarWinds strongly recommends securing information used to authenticate to CyberArk.
Use a strong encryption algorithm and passphrase
Password fields in cyberark.properties are automatically encrypted after DPA startup. To use a strong encryption algorithm and passphrase:
- Open DPA in your browser.
- From the DPA menu in the upper-right corner, click Options.
- Under Administration > Configuration, click Password Encryption Settings.
- Under Choose an encryption scheme, select AES 256-bit.
Enter your Encryption Passphrase.
Do not share the passphrase with anyone.
Click Update.
Passwords stored in DPA configuration files or in the DPA repository are re-encrypted using your selection.
Limit access to the files storing sensitive information
Make sure that, except for the user running DPA service (Windows) or process (Linux), no one has read permission to the CyberArk configuration file (cyberark.properties) and CyberArk client certificate (referenced from cyberark.properties).
For the user running the DPA service or process, read permission is sufficient for the CyberArk client certificate. Both read and write permissions are needed for the cyberark.properties file (so DPA can encrypt the password fields).
When you install DPA on a Linux server, make sure you do not install DPA under the root user. Using a dedicated DPA user instead of the root user gives you flexibility to set the permissions as described above.
When you install DPA on a Windows server, the Ignite_PI service runs under the “Local System Account” by default. To use a dedicated DPA user instead, complete the following steps:
- Open a command prompt, and enter
services.msc. - Right-click the Ignite PI Server service and select Properties.
- On the Log On tab, click This Account and enter the credentials for the account you want to use.
Be aware that after you upgrade DPA, the Ignite_PI service is recreated and “Local System Account” is used again. You must manually update the service after every DPA upgrade.
