Purchase and view DPA licenses
For DPA servers that use licenses, DPA has a 14-day evaluation license. During the evaluation period, you can monitor and view data for an unlimited number of database instances. After the evaluation period, to continue monitoring you must buy the correct quantity and type of licenses for your database instances.
  • DPA has its own licensing and does not work with SolarWinds License Manager.
  • If your DPA server is deployed in the Amazon Web Services (AWS) Marketplace, DPA uses the AWS Marketplace Metering Service to calculate charges. You do not need to purchase, activate, or allocate licenses.
Purchase licenses
Contact our sales team to purchase licenses directly from SolarWinds.
Only buy licenses for active database instances. Standby database instances used for disaster recovery or high availability do not need licenses.
View purchased licenses
After you purchase licenses, you can view your DPA licenses in the SolarWinds Customer Portal.
  1. Access the Customer Portal.
  2. Click Licenses > Manage Licenses.
    The licenses for your DPA product are listed by license type.
Next steps
After you have bought licenses, you must activate them on a DPA server, register database instances for monitoring, and then allocate licenses to the registered instances.
