Register an Azure Database for MariaDB
Complete the following steps to register an individual Azure Database for MariaDB database instance for monitoring with DPA.
You can also use mass registration to registrations to register multiple database instances, or you can register database instances using scripts that call the DPA API.
If you register a database instance within the 14-day trial period, DPA begins monitoring the instance immediately. After the trial period, you must activate a license to monitor the database instance.
Task 1: Create the monitoring user
Complete the following steps to create the user that DPA will use to monitor the database instance. Alternatively, you can specify an Azure AD Service Principal if you don’t want to create, manage, and update user credentials.
  1. Create the DPA monitoring user in Azure Database for MariaDB. For more information, see Create users in Azure Database for MariaDB in the Azure documentation.
  2. Run the following commands to grant the monitoring user the privileges required for monitoring:
    GRANT SELECT ON performance_schema.* TO 'dpa_user'@'%';
    GRANT UPDATE ON performance_schema.* TO 'dpa_user'@'%';
    GRANT PROCESS ON *.* TO 'dpa_user'@'%';
    GRANT SELECT ON *.* TO 'dpa_user'@'%';
  3. Run the following commands to grant the monitoring user the privileges required to enable the retrieval of query execution plans:
    GRANT INSERT ON *.* TO 'dpa_user'@'%';
    GRANT UPDATE ON *.* TO 'dpa_user'@'%';
    GRANT DELETE ON *.* TO 'dpa_user'@'%';
Task 2: Register the database instance
  1. In the upper-left corner of the DPA home page, click Register DB Instance for Monitoring.
  2. Under Microsoft Azure, select Azure Database for MariaDB. Then click Next.
  3. On the Connection information panel, enter the host name or IP address of the database instance.
  4. Enter the port number.
  5. Under SSL mode, specify the type of secure socket layer (SSL) connections established between the instance and the DPA server.
    SSL mode Description
    Disable SSL encryption is not used.
    Require SSL is enabled, but no server certificate checks are performed. This SSL configuration does not protect against man-in-the-middle attack because no certificate is required.
    Verify-CA
    SSL is enabled. The client verifies that the server is trustworthy by checking the certificate chain up to a trusted certificate authority (CA).
    If you select this option and DPA cannot access a trusted certificate, you are prompted to import a certificate into the DPA trust store. Click the blue arrow to view certificate details.
    Verify-Identity
    SSL is enabled. The client verifies the certificate chain and also verifies that the server hostname matches its certificate's Subject Alternative Name or Common Name (CN).
  6. Enter the user name and password of the monitoring user created previously. Or, if DPA is configured to use CyberArk, enter the CyberArk credentials query for the monitoring user. Then click Next.
    DPA validates the connection information and the privileges of the monitoring user.
    DPA does not support connecting to the instance through a gateway.
  7. Specify the following Instance Options.
    The instance name and group membership can be changed after registration.
    1. Enter the name that DPA will display to identify this database instance.
      The Display name field defaults to the name retrieved from the database instance.
    2. (Optional) If you have manually created instance groups, you can assign this database instance to one of the groups.
      If no manual groups exist, this option is not shown.
    3. (Optional) If you have existing alert groups, you can assign this database instance to one or more groups.
      If no alert groups exist, or the existing groups do not match this instance's database type, this option is not shown.
    4. Click Next.
  8. Review the information on the Summary page. Click Back if you need to make changes. When the information is correct, click Register.
