View trusted certificates in the Java trust store
Certificates in the Java trust store can be used by any Java application. DPA can use these certificates to connect to any database instance or LDAP server.
These certificates are located (by default) at DPA-install-dir\iwc\jre\lib\security\cacerts, and they are not managed through DPA. You can use DPA to view the names and expiration dates of these certificates.
  1. From the DPA menu in the upper-right corner, click Options.
  2. Under Administration > Configuration, click Trusted Certificate Management.
    The Trusted Certificate Management page opens.
  3. Click Java Trust Store.
    The Java Trust Store tab lists the alias and expiration date of each certificate in the Java trust store. You can:
    • Sort by alias or expiration date. Click the down arrow to select the attribute you want to sort by. Click the sort button to reverse the sort order.
    • Enter a string in the search field to search for a certificate by alias name. The list is filtered to show only certificates whose name includes the search string.
