Examples of using Python scripts to make DPA API calls
The following examples show Python scripts that call the DPA API to retrieve information and perform DPA management functions. The first examples are snippets that demonstrate each API call individually. The last example is a full script that shows how to put the snippets together into a working script.
You can call the DPA API with any programming language that can send HTTP requests. See this topic for PowerShell script examples.
See the following sections:
Prerequisites
  • Before you can use scripts to make API calls, you must create a refresh token.
  • These examples use the Requests HTTP library for Python. This library must be installed for these examples to work.
If your DPA server does not use HTTPS or your certificates are self-signed
The examples all use HTTPS, which can cause problems if your DPA server is not configured to use HTTPS or if your certificates are self signed. If this is the case, you can do either of the following:
  • Run the examples using HTTP.
  • Change the verify_cert value to False in the configuration section to prevent verifying the server's TLS certificate.
# Configure the variables below for the DPA Host
base_url = "https://localhost:8124/iwc/api/"
refresh_token = "eyJhbGciOiJIUzI1NiJ9.eyJzdWIiOiJNeVRva2VuIiwiaXN..."
verify_cert = False
Get an access token
The first step in using the API is to get an access token. An access token is required to make any API calls. This call POSTs the refresh token to DPA, which returns an access token to be used by all other API calls.
  • If the call is successful, it prints out the data that was returned from DPA, including the access_token, and then goes on to create HTTP Headers that will contain the access token and other information to be used on subsequent calls.
  • If the call is not successful it prints out the error message.
You must set the base_url and the refresh_token variables to match your environment.
verify_cert = True
# Get Access Token
def get_access_header(prefix_url, rfrsh_token):
  Given a base url and a refresh token retrieve the access token
  and return a header object with it.
  :param prefix_url: the base url
  :param rfrsh_token: refresh token used to get access token
  :return: the request header that contains the access token
  :rtype: dict
  auth_token_url = prefix_url + "security/oauth/token"
  grant_type = "refresh_token"
  payload = {"grant_type": grant_type, "refresh_token": rfrsh_token}
  try:
    # get an access token
    resp = requests.post(auth_token_url, data=payload, verify=verify_cert)
    resp.raise_for_status()
    resp_json = resp.json()
    token_type = resp_json["token_type"]
    access_code = resp_json["access_token"]
    headers = {"authorization": f"{token_type} {access_code}",
      "content-type": "application/json;charset=UTF-8",
      "accept": "application/json"
    return headers
  except requests.exceptions.HTTPError as ex:
    print(ex)
    print(ex.response.text)
    # print(json.dumps(json.loads(ex.response.text), indent=2))
    return None  # requests is bad return None, can't get access_code
# get the header that contains access token for authentication
header = get_access_header(base_url, refresh_token)
if header is None:
  sys.exit(0)
Database Monitor examples
The following examples show how to use Database Monitor calls.
Get information about one monitored database instance
# Get information about a single monitored database instance
database_id = 1
monitor_url = f"{base_url}databases/{database_id}/monitor-information"
single_monitor = None
try:
  print(f"\n*** Get Monitor Information for database with id of {database_id} ***")
  response = requests.get(monitor_url, headers=header, verify=verify_cert)
  response.raise_for_status()
  response_json = response.json()
  single_monitor = response_json["data"]
  print(json.dumps(single_monitor, indent=2))
except requests.exceptions.HTTPError as e:
  print(e)
  print(e.response.text)
# This will print out data like this:
*** Get Monitor Information for database with id of 1 ***
  "dbId": 1,
  "name": "DEV-DPA\SQLEXPRESS",
  "ip": "127.0.0.1",
  "port": "1433",
  "jdbcUrlProperties": "applicationIntent=readOnly",
  "connectionProperties": null,
  "databaseType": "SQL Server",
  "databaseVersion": "12.0.6205.1",
  "databaseEdition": "Enterprise Edition: Core-based Licensing (64-bit)",
  "monitoringUser": "ignite_next",
  "defaultDbLicenseCategory": "DPACAT2",
  "assignedDbLicenseCategory": "DPACAT2",
  "assignedVmLicenseCategory": null,
  "monitorState": "Monitor Stopped",
  "oldestMonitoringDate": "2018-12-09T00:00:00.000-07:00",
  "latestMonitoringDate": "2019-01-07T00:00:00.000-07:00",
  "agListenerName": null,
  "agClusterName": null,
  "agName": null,
  "racInfo": null,
  "rac": false,
  "rds": false,
  "ebusiness": false,
  "linkedToVirtualMachine": false,
  "pdb": false
Start and stop monitoring a database instance given its database ID
database_id = 1
monitor_url = f"{base_url}databases/{database_id}/monitor-status"
try:
  # Start monitoring a database instance given its database ID.
  print(f"*** Start Monitor for database {database_id} ***")
  body = {"command": "START"}
  response = requests.put(monitor_url, json=body, headers=header, verify=verify_cert)
  print(json.dumps(response_json["data"], indent=2))
  print("Waiting 15 seconds...")
  time.sleep(15)
  # Stop monitoring a database instance given its database ID.
  print(f"*** Stop Monitor for database {database_id} ***")
  body = {"command": "STOP"}
  time.sleep(15)
  print(e)
*** Start Monitor for database 1 ***
"SUCCESS"
*** Stop Monitor for database 1 ***
"SUCCESS"
Get information about all monitored database instances
database_id = 1
monitor_url = f"{base_url}databases/monitor-information"
try:
  print("*** Get Information for a all database instances ***")
  data = response_json["data"]
  print(json.dumps(data, indent=2))
  print(e)
*** Get information for all database instances ***
    "dbId": 1,
    "ip": "127.0.0.1",
    "port": "1433",
    "agName": null,
    "racInfo": null,
    "rac": false,
    "rds": false,
    "ebusiness": false,
    "pdb": false
    "dbId": 2,
    "name": "DEV-MYSQL",
    "ip": "127.0.0.1",
Stop and start monitoring for all database instances
# Start monitoring all database instances.
monitor_url = f"{base_url}databases/monitor-status"
try:
  print("*** Starting all Monitors ***")
  print("Waiting 30 seconds...")
  time.sleep(30)
  print(e)
# Stop monitoring all database instances.
try:
  print("*** Stopping all Monitors ***")
  time.sleep(30)
  print(e)
"SUCCESS"
"SUCCESS"
Update the user password for a monitored database instance
database_id = 1
monitor_url = f"{base_url}databases/{database_id}/update-password"
try:
  print(f"*** Update the Monitor password for database {database_id} ***")
  body = {"password": "NewPassword!"}
  print(e)
*** Update the Monitor password for database 1 ***
"SUCCESS"
License Allocation examples
The examples below show how to use License Allocation calls.
Get information about currently installed licenses
license_url = f"{base_url}databases/licenses/installed"
try:
  print("\n*** Getting Installed license information with total amounts available for use and total amounts used ***")
  response = requests.get(license_url, headers=header, verify=verify_cert)
  print("licenseProduct licenseCategory licensesAvailable licensesConsumed")
  print("-------------- --------------- ----------------- ----------------")
  for i in range(len(data)):
    print('{:<15s}{:<16s}{:>17d}{:>17d}'.format(data[i]["licenseProduct"], data[i] ["licenseCategory"],
				                                            data[i]["licensesAvailable"], data[i]["licensesConsumed"]))
  print(e)
DPACAT1        DPA_DB                        100               22
DPACAT2        DPA_DB                        100               16
DPAAzureSQL    DPA_DB                          0                0
DPAVM          DPA_VM                        100               12
Get license information for a single database instance
database_id = 1
license_url = f"{base_url}databases/{database_id}/licenses"
try:
  print(f"\n*** Getting current license information for the database instance with database ID of {database_id} ***")
  print(e)
*** Getting current license information for the database instance with database ID of 1 ***
  "serverName": "DEV-DPA",
  "overLicensed": false,
  "performanceLicenseProduct": "DPACAT2",
  "vmLicenseProduct": "DPAVM"
Update license information for a database instance
database_id = 1
# Add a DPACAT2 and a DPAVM license
body = {"performanceLicenseProduct": "DPACAT2",
	"vmLicenseProduct": "DPAVM"}
try:
  print(f"\n*** Updating license for database id {database_id} ***")
  response = requests.put(license_url, json=body, headers=header, verify=verify_cert)
  print(e)
# Remove the DPAVM license
	 "vmLicenseProduct": "REMOVE"}
try:
  print(e)
*** Updating license for database id 1 ***
  "serverName": "DEV-BOU-CALLEN",
  "vmLicenseProduct": DPAVM
  "vmLicenseProduct": null
Annotation examples
The examples below show how to use Annotation calls.
Get a list of annotations for the last 30 days
# Gets a List of annotations for the last 30 days
database_id = 1
annotation_url = f"{base_url}databases/{database_id}/annotations"
# Dates are in ISO 8601 format ( 2018-12-31T12:00:00.000-07:00 )
end_time = datetime.datetime.now()
start_time = end_time + datetime.timedelta(days=-30)
args = {"startTime": start_time.astimezone().isoformat(),
	 "endTime": end_time.astimezone().isoformat()}
try:
  print("\n*** Getting Annotations for the last 30 days ***")
  response = requests.get(annotation_url, params=args, headers=header, verify=verify_cert)
  print(e)
    "id": 112,
    "title": "Test Title API",
    "description": "Test Event created by DPA API",
    "createdBy": "DPA API",
    "time": "2018-12-11T10:01:35-07:00",
    "type": "API"
    "id": 113,
    "time": "2018-12-12T15:00:40-07:00",
    "type": "API"
Create a new annotation
database_id = 1
# Dates are in ISO 8601 format, no millis ( 2018-12-31T12:00:00-07:00 )
create_time = datetime.datetime.now().replace(microsecond=0)
body = {"title": "API Test Title",
  "description": "API Test Description",
  "createdBy": "Test API User",
  "time": create_time.astimezone().isoformat()}
try:
  print("\n*** Creating Annotation ***")
  response = requests.post(annotation_url, json=body, headers=header, verify=verify_cert)
  print(e)
  "id": 171,
  "time": "2019-01-09T11:04:33-07:00",
  "type": "API"
Delete an annotation
database_id = 1
annotation_id = 171
annotation_url = f"{base_url}databases/{database_id}/annotations/{annotation_id}"
try:
  print(f"\n*** Deleting Annotation with id of {annotation_id} ***")
  response = requests.delete(annotation_url, headers=header, verify=verify_cert)
  if response.status_code == 204:
    print(f"Annotation with id of {annotation_id} deleted")
  print(e)
*** Deleting Annotation with id of 171 ***
Annotation with id of 171 deleted
Database Registration examples
The examples below show how to use Database Registration calls.
Register and unregister a SQL Server database instance for monitoring
This example registers a new SQL Server database instance, waits 60 seconds, and then unregisters the database instance.
# Register a SQL Server database instance for monitoring.
registration_url = f"{base_url}databases/register-monitor"
body = {"databaseType": "SQLSERVER",
        "serverName": "127.0.0.1",
        "port": "1433",
        "sysAdminUser": "sa",
        "sysAdminPassword": "Password",
        "monitoringUser": "dpa_test_m",
        "monitoringUserPassword": "Password",
        "monitoringUserIsNew": True,
        "displayName": "DPA_SQL2K12"}
new_db_id = None
try:
  print("\n*** Register SQL Server database ***")
  response = requests.post(registration_url, json=body, headers=header, verify=verify_cert)
  responseJson = response.json()
  data = responseJson["data"]
  new_db_id = data["databaseId"]
  print(e)
print("Waiting 60 seconds...")
time.sleep(60)
# Unregister the SQL Server database instance.
registration_url = f"{base_url}databases/unregister-monitor"
body = {"databaseId": new_db_id,
        "removeMonitoringUser": True,
        "removeDatabaseObjects": True,
        "sysAdminPassword": "Password"}
try:
  print(f"\n*** Unregister SQL Server database [{new_db_id}] ***")
  print(json.dumps(responseJson["data"], indent=2))
  print(e)
  "databaseId": 77,
  "result": "SUCCESS"
*** Unregister SQL Server database [77] ***
  "databaseId": 77,
  "result": "SUCCESS"
Register and unregister an Oracle database instance for monitoring
This example registers a new Oracle database instance, waits 60 seconds, and then unregisters the database instance.
# Register an Oracle database instance for monitoring.
body = {"databaseType": "ORACLE",
        "serviceNameOrSID": "DPA_ORA11R1",
        "port": "1521",
        "sysAdminUser": "system",
        "sysPassword": "Password",
        "monitoringUserTableSpace": "USERS",
        "monitoringUserTempTableSpace": "TEMP",
        "oracleEBusinessEnabled": False,
        "displayName": "DPA_ORA11R1"}
new_db_id = None
try:
  print("\n*** Register Oracle database ***")
  print(e)
time.sleep(60)
# Unregister the Oracle database instance.
try:
  print(f"\n*** Unregister Oracle database [{new_db_id}] ***")
  print(e)
  "databaseId": 78,
  "result": "SUCCESS"
*** Unregister Oracle database [78] ***
  "databaseId": 78,
  "result": "SUCCESS"
Register and unregister a MySQL database instance for monitoring
This example registers a new MySQL database instance, waits 60 seconds, and then unregisters the database instance.
# Register a MySQL database instance for monitoring.
body = {"databaseType": "MYSQL",
        "port": "3306",
        "sysAdminUser": "root",
        "displayName": "DPA_MYSQL56"}
new_db_id = None
try:
  print("\n*** Register MySQL database ***")
  print(e)
time.sleep(60)
# Unregister the MySQL database instance.
try:
  print(f"\n*** Unregister MySQL database [{new_db_id}] ***")
  print(e)
  "databaseId": 79,
  "result": "SUCCESS"
*** Unregister MySQL database [79] ***
  "databaseId": 79,
  "result": "SUCCESS"
Database Custom Properties examples
The examples below show how to use Database Custom Properties calls. Custom property values can be included in custom email templates for alert notifications.
Create a custom property
This script creates a custom property and defines its name and description.
property_name = "Location"
property_description = "Location of the database server"
create_property_url = f"{base_url}databases/properties"
body = {
  "name": property_name,
  "description": property_description
property_id = None
try:
  print("\n*** Creating custom property ***")
  response = requests.post(create_property_url, json=body, headers=header, verify=verify_cert)
  property_id = data["id"]
  print(e)
#This will print out data like this:
  "id": 1,
  "name": "Location",
  "description": "Location of the database server"
Create a custom property value
This script creates a value for the custom property created by the previous script.
property_id = 1
property_value = "New York"
create_value_url = f"{base_url}databases/properties/" + str(property_id) + "/values"
body = property_value
property_value_id = None
try:
  print("\n*** Creating custom property value ***")
  response = requests.post(create_value_url, data=body, headers=header, verify=verify_cert)
  property_value_id = data["id"]
  print(e)
  "id": 1,
  "value": "New York"
Assign a property value to a monitored database instance
This script assigns a property value to a monitored database instance.
property_id = 1
property_value_id = 1
database_id = 1
assign_property_value_url = f"{base_url}databases/" + str(database_id) + "/properties/" + str(property_id) + "/values/" + str(property_value_id)
try:
  print("\n*** Assigning custom property value ***")
  response = requests.post(assign_property_value_url, headers=header, verify=verify_cert)
  if response.status_code == 200:
  print(f"Custom property value assigned to the DB with ID: {database_id}")
  print(e)
#Custom property value assigned to the DB with ID: 1
Get all information about properties
This script returns information about all custom properties and their values.
get_properties_url = f"{base_url}databases/properties?require=assignment"
try:
  print("\n*** Getting custom property information ***")
  response = requests.get(get_properties_url, headers=header, verify=verify_cert)
  print(e)
    "id": 1,
    "name": "Location",
    "description": "Location of the database server",
    "values": [
        "id": 1,
        "value": "New York",
        "assignment": [
          1
    "unassigned": [
      2
Delete a custom property
This script deletes a custom property.
property_id = 1
delete_property_url = f"{base_url}databases/properties/" + str(property_id)
try:
  print("\n*** Deleting custom property ***")
  response = requests.delete(delete_property_url, headers=header, verify=verify_cert)
  print(f"Custom property with ID of {property_id} deleted")
  print(e)
#Custom property with ID of 1 deleted
Full working script
The following script combines all of the examples shown above into a script that can be run.
import json
import sys
import time
import datetime
import requests
base_url = "http://localhost:8124/iwc/api/"
verify_cert = True
# Get Access Token
  :rtype: dict
  try:
    return headers
    print(ex)
if header is None:
  sys.exit(0)
# Database Monitor Examples
# Calls for individual monitors...
# Get Monitor Information for a single database instance
database_id = 1
try:
  print(e)
# Start or Stop monitoring a database instance given its database ID.
# If it is already running stop it and then restart it
# If it is not running start it and then stop it
if single_monitor is not None:
  if single_monitor["monitorState"] == "Monitor Running":
    change_command = "STOP"
    revert_command = "START"
  elif single_monitor["monitorState"] == "Monitor Stopped":
    change_command = "START"
    revert_command = "STOP"
  else:
    change_command = None
    revert_command = None
  if change_command is not None:
    try:
      print(f"\n*** {change_command} Monitor for database {database_id} ***")
      body = {"command": change_command}
      time.sleep(15)
      print(f"\n*** {revert_command} Monitor for database {database_id} ***")
      body = {"command": revert_command}
      time.sleep(15)
      print(e)
# Calls for all monitors...
# Get Monitor Information for all database instances
database_id = 1
running_ids = []
try:
  print("\n*** Get Information for a all database instances ***")
  # Keep a list of running or started monitors to be used later
  for monitor in data:
    state = monitor["monitorState"]
    if state == "Monitor Running" or state == "Monitor Start No License" or 'Start' in state:
      running_ids.append(monitor["dbId"])
  print(f"Running Monitors: {running_ids}")
  print(e)
try:
  print("\n*** Starting all Monitors ***")
  time.sleep(30)
  print(e)
try:
  print("\n*** Stopping all Monitors ***")
  time.sleep(30)
  print(e)
# Try to put it back the way we found it by restarting the ones that were running
for db_id in running_ids:
  try:
    print(f"\n*** Starting Monitor for database {db_id} ***")
    monitor_url = f"{base_url}databases/{db_id}/monitor-status"
    print(e)
# Update the monitor database user password (Un-comment to use)
#monitor_url = f"{base_url}databases/{database_id}/update-password"
#try:
#  print(f"*** Update the Monitor password for database {database_id} ***")
#  body = {"password": "Password"}
#  response = requests.put(monitor_url, json=body, headers=header, verify=verify_cert)
#  response.raise_for_status()
#  response_json = response.json()
#  print(json.dumps(response_json["data"], indent=2))
#except requests.exceptions.HTTPError as e:
#  print(e)
#  print(e.response.text)
# Licensing Examples
# Get the currently installed license information
try:
    print('{:<15s}{:<16s}{:>17d}{:>17d}'.format(data[i]["licenseProduct"], data[i]["licenseCategory"],
  print(e)
# Get License Information for a single database
license_info = None
try:
  license_info = response_json["data"]
  print(json.dumps(license_info, indent=2))
  print(e)
# This will Update License Information for a single database setting the
# Performance License and the VM License to what it currently is.
# It should succeed but it should make no changes.
if license_info is not None:
  database_id = 1
  db_product = license_info["performanceLicenseProduct"]
  vm_product = license_info["vmLicenseProduct"]
  body = {"performanceLicenseProduct": db_product,
    "vmLicenseProduct": vm_product}
try:
  print(e)
# Annotation Examples
try:
  print(e)
# Create a new annotation
annotation_id = None
#Dates are in ISO 8601 format, no millis ( 2018-12-31T12:00:00-07:00 )
try:
  annotation_id = data["id"]
  print(e)
# Delete an annotation
if annotation_id is not None:
  try:
    print(e)
# Registration Examples
        "port": "1433",
        "sysAdminUser": "User",
new_db_id = None
try:
  print(e)
time.sleep(60)
# Un-register the SQL Server database instance.
try:
  print(e)
        "port": "1521",
new_db_id = None
try:
  print(e)
time.sleep(60)
# Un-register the Oracle database instance.
try:
  print(e)
        "port": "3306",
new_db_id = None
try:
  print(e)
time.sleep(60)
# Un-register the MySQL database instance.
try:
  print(e)
# Custom Property Examples
# Create custom property
body = {
property_id = None
try:
  print(e)
# Create value of the custom property
try:
  print(e)
# Assign property value to DB
try:
  print(e)
# Get all information about properties (including DB assignment)
try:
  print(e)
# Delete custom property
try:
  print(f"Custom property with id of {property_id} deleted")
  print(e)
