System requirements for a stand-alone installation of SolarWinds VNQM
The following requirements are based on a minimum installation of SolarWinds VoIP and Network Quality Manager with SQL Server on a separate database server. If you are installing SolarWinds VNQM into an existing Orion Platform installation, see the multi-module system guidelines.
To optimize database scalability, SolarWinds recommends that you maintain your SQL Server installation on its own server. If you must host your SQL server on the same server, SolarWinds recommends at least a quad-processor, 2.67 GHz, 64-bit CPU and 16 GB of RAM.
SolarWinds VoIP and Network Quality Manager requirements
hardware or software
requirements
Environment
SolarWinds VoIP and Network Quality Manager supports IP SLA for Cisco IP SLA capable devices. It is possible to monitor Cisco CallManager, CallManager Express, and Avaya Communication and Media Server devices with SolarWinds VoIP and Network Quality Manager.
CPU
Dual processor, 3GHz
RAM
8 GB
Hard drive space
20 GB
Operating system
Windows Server 2008 R2 SP1
Windows Server 2012, 2012 R2
Windows Server 2016
.NET Framework
Version 4.5
Compatible with 4.6.1
Web browser
Internet Explorer 11
Microsoft Edge
Mozilla Firefox - two most recent versions
Google Chrome - two most recent versions
SQL Server requirements
requirements
CPU
Dual processor, 3 GHz
Quad-processor, 2.67 GHz, 64-bit (for large networks)
RAM
8 GB
16 GB (for large networks)
Hard drive space
20 GB
Database
SQL Server 2008, 2008 SP1, 2008 SP2, 2008 SP3, or 2008 SP4
SQL Server 2008 R2, 2008 R2 SP1, 2008 R2 SP2, or 2008 R2 SP3
SQL Server 2012, 2012 SP1, 2012 SP2, or 2012 SP3 (also with AlwaysOn Availability Groups)
SQL Server 2014 (also with AlwaysOn Availability Groups) or 2014 SP1
SQL Server 2016 RC
If you anticipate up to six million standard, device to device calls per month with a peak hour of 20,000 calls, SolarWinds recommends using a dedicated SQL server with a 64-bit, 2.67 GHz quad-processor CPU and 16 GB of RAM. SolarWinds VNQM does not support more than six million calls per month.
Port requirements
Port # Protocol Service / process Direction Description
21 TCP SolarWinds Collector Service Bidirectional The port used for FTP (CDR/CMR download)
22 TCP SolarWinds Collector Service Bidirectional The port used for SFTP (CDR/CMR download) SSH for CLI (operation polling)
23 TCP SolarWinds Collector Service Bidirectional The port used for TELNET for CLI (operation polling)
80 TCP World Wide Web Publishing Service Bidirectional HTTP port
The default port used by Additional Web Servers. If you change this setting, you must include the port in the URL used to access the Orion Web Console.
161 UDP SolarWinds Collector Service Outbound The default UDP port of NPM, used by SNMP.
443 TCP World Wide Web Publishing Service Bidirectional The port used for conducting secure SSL communications.
5022 TCP SolarWinds Collector Service Bidirectional The port used for communication with Avaya Call Manager via CLI through SSH.
5005 UDP SolarWinds Collector Service Bidirectional
The port used for RTCP data (call metrics) listening from Avaya Call Manager.
8443 HTTPS SolarWinds Orion Module Engine/Business Layer Plugin Outbound The port used for troubleshooting Cisco Call Manager AXL credentials.
17777 TCP SolarWinds Information Service Bidirectional The port used forcommunication from your polling engine to the Orion Web Console, and from the Orion Web Console to your polling engine.
50000 TCP SolarWinds Collector Service Bidirectional The port used for CDR data (call records) listening from Avaya Call Manager.
