Documentation forVoIP & Network Quality Manager
Monitoring VoIP and network quality is a key capability of Hybrid Cloud Observability and is also available in a standalone module, VoIP & Network Quality Manager (VNQM). Hybrid Cloud Observability and VNQM are built on the self-hosted SolarWinds Platform.
Edit CLI credentials for gateway nodes
For monitoring gateway nodes, VNQM uses CLI credentials.
To edit CLI credentials, complete the following steps:
  1. Log in to your SolarWinds VoIP and Network Quality Manager server as an administrator.
  2. Click Settings > All Settings.
  3. Under Product Specific Settings, click VoIP & Network Quality (VNQM) Settings.
  4. Click Manage Gateways.
  5. Select the node you want to edit, and click Edit CLI Credentials.
  6. Select the appropriate settings from the Select Credentials list or define new credentials.
    To define a new set of CLI credentials, provide the following details:
    • Select Credentials
      Enter the name of the new credential set.
    • Username
    • Password
    • Enable Level
      Select the enable level to use when logging in.
      The enable level must have privileges to execute terminal commands. SolarWinds VoIP and Network Quality Manager uses Show commands to fetch and display data from the gateway. For information about configuring network devices, see your manufacturer’s documentation.
    • Enable Password
      Enter the password associated with the enable level to use when logging in.
  7. Expand Advanced, and select the Protocol, Port Number, and Connection Timeout you want to use when connecting to your network devices.
  8. Click Test to test the credentials.
  9. Click Save to apply your changes.
