Site Profiles Toolbar
This toolbar provides common controls used to manage site profiles. Certain buttons are enabled or disabled based on the current selection and state of the item within the Site Profiles List.
The toolbar buttons are described below:
Connect | Establishes a new connection to the remote server by opening a new Remote Browser. |
New Site | Creates a new site under the selected folder within the Site Profiles List. |
Wizard | Launches the New Site Wizard. |
New Folder |
Creates a new folder under the selected folder within the Site Profiles List. |
Delete | Deletes the selected folder from the Site Profiles List. |
Save |
All changes are saved to the site profile. |
Import |
Displays a dialog that allows you to import site profiles from a previous installation of FTP Voyager. |
Export |
Displays a dialog that allows you to export FTP Voyager site profiles to a "CSV" or "TXT" file. |
Help |
Displays the help documentation for FTP Voyager. |
