Tools Tab Overview
The Tools tab includes access to global FTP Voyager settings regarding server interaction and user interface preferences, and also includes search, synchronize, and file transfer scheduling functionality.
The Tools tab consists of 3 groups:
Display
Options |
Use this to display the Options where you can modify user interface preferences, proxy settings, ASCII extensions, and more. |
Search |
Searches for files in the active browser according to the search terms. Once clicked, focus is automatically moved to the Search Bar of the active file browser. |
Session
Stop |
Stops the current operation, whether it is a file transfer, directory listing, or other. |
Custom Commands |
Issues a pre-defined custom command to the server. Custom commands can be added for specific servers as needed (see the Help documentation within Custom Commands Dialog for more details). All server responses can be viewed within the Log Pane. FTP Voyager provides default custom commands which are described below:
Send FTP Command |
Use the Send FTP Command dialog to send a custom or manual FTP command to an FTP server. This only applies to FTP servers, SFTP servers are not supported. |
Synchronize Folders |
Allows for synchronization of files and folders between two file browsers. Please see Synchronize Folders for more information. |
Scheduler
Scheduler Site Profiles |
Defines site profiles to be used specifically with FTP Voyager Scheduler. All site profiles managed here only apply to FTP Voyager Scheduler. You can add existing site profiles from FTP Voyager to the site profiles of FTP Voyager Scheduler. Open the Site Profile Manager for FTP Voyager, right-click on a site profile and select Copy to Scheduler. |
Scheduler Options |
Defines "global" options specifically used for FTP Voyager Scheduler. All options and settings adjusted here only apply to FTP Voyager Scheduler. |
