Quick Access Toolbar overview
A Quick Access Toolbar is a small, customizable toolbar that displays frequently used commands. Certain commands within the Ribbon can be added to the Quick Access Toolbar by right-clicking on the button and selecting Add to Quick Access Toolbar. Once the command has been added to the toolbar, each one can be shown or hidden by selecting its corresponding item in the drop-menu located on the right-side of the Quick Access Toolbar. To remove a command from the Quick Access Toolbar, right-click on the button and select Remove from Quick Access Toolbar.
The drop-menu also allows you to:
- Minimize the ribbon which will hide the tab buttons.
- Move the Quick Access Toolbar below the tabs.
