Transfer Queue Toolbar
The toolbar provides common controls used to manage the each file transfer. Certain buttons are enabled or disabled based on the current selection and state of the transfer item.
The toolbar buttons are described below:
Stop Selected Transfers |
All transfer items within the current selection are stopped. |
Skip Selected Transfers | All transfer items within the current selection are skipped. | ||||||||||||||||||||||
Pause Selected Transfers | All transfer items within the current selection are paused. | ||||||||||||||||||||||
Resume Selected Transfers |
All transfer items within current selection which are paused, are resumed. |
Remove Selected Transfers |
All transfer items within the current selection are removed from the queue. |
Remove All Completed Transfers |
All completed transfer items are removed from the queue. |
Number of Workers |
Allocates the number of worker threads that the Transfer Queue can use. Worker threads carry out any pending transfers that need to be performed. The Transfer Queue can have a minimum of 1 worker up to a maximum of 9. The default number of workers is 4. |
Settings |
Click to show a pop-up window with extended settings. Each setting is described below:
Click here to produce a pop-up window with pre-defined actions that FTP Voyager can perform when the entire transfer queue has been processed. The actions, upon queue completion, are listed below:
Do Nothing | Does nothing upon queue completion. |
Close Application | Exits FTP Voyager. |
Lock computer | Locks the workstation. |
Log off | Logs the user out of the workstation. |
Hibernate | Hibernates the workstation. |
Sleep | |
Shutdown computer | |
Display message box | |
Display notification | Display a notification window on the desktop. |
Beep |
