Transfer Queue Pane Overview
The Transfer Queue pane displays a history of files and folders that are transferred between the local file system and a remote file server. For example, when a local file within the local browser is uploaded to a remote browser, a row is inserted here that represents the upload process of that local file. The Transfer Queue has many options that control the transfers that are taking place. Common options are located on the toolbar. Extra options can be accessed by right-clicking which displays a pop-up menu.
A status bar is also provided which displays important information pertaining to the configuration and state of the Transfer Queue.
The Transfer Queue has several columns that pertain to the transfer process. These are described below:
Status | Displays images that correspond to the state of the transfer item.
The various states are described below:
Operation | Displays the operation that occurs for this particular item.
The various operations are described below:
Name | Displays the name of the file that is being transferred. The name field also identifies groupings. Groupings have custom numbers that correspond to each items place within the grouping. For example, when two files are uploaded, their file names are appended with: "(1 of 2)" and "(2 of 2)" respectively. | |||||||||||||||||||||
Transferred | Displays the individual progress for the file that is being transferred. | |||||||||||||||||||||
Completion | Displays the rate of which the transfer is occurring and provides an estimated time of arrival for the file to reach its destination. | |||||||||||||||||||||
Overall | Displays the progress for the individual file that is being transferred or the overall progress of a transfer grouping.
A transfer grouping can be identified within the "Name" column which appends the numbers of items that are within the group. |
Source Path | Displays the absolute file path of where the file came from. | |||||||||||||||||||||
Destination Path | Displays the absolute file path of where the file is going. |
