Open Files Toolbar
This toolbar provides common controls used to manage open files. Certain buttons are enabled or disabled based on the current selection and state of the item.
The toolbar buttons are described below:
Reconnect to Site |
Opens a new Remote Browser for each file that is selected. |
Open |
Opens the currently selected files within the default program registered for each file type. Once opened, you can edit the file and then upload your changes to the remote server. |
Upload and Keep in List |
Uploads the selected files to their remote server location and keeps them within the list. |
Upload and Remove from List |
Uploads the selected files to their remote server location and removes them from the list. |
Discard Changes and Remove from List |
All selected items will be removed from the list without uploading any changes to the remote server. |
Discard All Changes and Remove from List |
All items will be removed from the list without uploading any changes to the remote server. |
