Ribbon Customization
With the introduction of the new Ribbon within FTP Voyager, you can customize it to suit your needs. To customize the Ribbon, click on the Customize Quick Access Toolbar drop-down which is located within the title bar of the main application window (see screenshot below).
The main options within this drop-down are:
More Commands | Select this option to launch a dialog which allows you to add/remove buttons from the Quick Access Toolbar. |
Minimize the Ribbon |
Show Below the Ribbon | Select this option to show the Quick Access Toolbar below the Ribbon. |
