Trusted Certificates
Upon connecting to an FTPS server, FTP Voyager users are prompted with the SSL certificate presented by the server as well as any possible problems with the certificate. If the certificate is marked as Trusted, FTP Voyager stores the certificate permanently within this page which is located under the Trusted Certificates category within the Options dialog.
Use the buttons below to manage trusted certificates:
View | Click to view the entire contents of the selected certificate. Please see SSL Certificate dialog for more details. |
Remove | Click to remove the selected certificate from the "Trusted Certificates" list. |
Import | Click to import a certificate. Importing allows you to add a trusted certificate to this "Trusted Certificates" list within FTP Voyager. |
Export | Click to export the certificate. Exporting allows you to backup or move the trusted certificate to another location. |
