Transfer Operations
Settings that affect the Transfer Queue Pane are located here. The Transfer Queue Pane can be configured to display a summary or extended details of file operations. Certain file operations can be filtered out to produce a list of file operations that are important to you. Customization settings pertaining to the Transfer Queue Pane are as follows:
Options pertaining to this page are described below:
File operations |
View | Changes the view of the Transfer Queue Pane to either a detailed view or a summary view. |
Pending Operations | Change how pending file operations are displayed within the Transfer Queue Pane. |
Completed Operations | Change how successful file operations are displayed within the Transfer Queue Pane. |
Operations to show |
File Download | Select Show to display transfer items that correspond to the downloading of a file. |
File Upload | Select Show to display transfer items that correspond to the uploading of a file. |
Rename | Select Show to display transfer items that correspond to the renaming of a file or folder. |
Delete | Select Show to display transfer items that correspond to the deletion of a file or folder. |
Create Folder | Select Show to display transfer items that correspond to the creation of a folder. |
Change Properties | Select Show to display transfer items that correspond to the modification of a file's or folder's properties. |
Get Directory Size | Select Show to display transfer items that correspond to the request of getting a remote directory's size. |
Search | Select Show to display transfer items that correspond to a search request. |
Compare Folders | Select Show to display transfer items that correspond to Compare Folders operations. |
Synchronize Folders | Select "Show to display transfer items that correspond to Synchronize Folders operations. |
Defaults Button
Press this button to reset all settings, on this page, back to their original settings.
