Prompts
Many operations require an acknowledgment from the user before FTP Voyager can carry out the operation. To turn on a confirmation, place a checkmark next to the corresponding setting. Each setting is explained in greater detail below:
Delete File |
Prompt when a file is deleted. In order to prevent an accidental deletion of a file, we recommend leaving this setting turned on. |
Delete Folder |
Prompt when a folder is deleted. In order to prevent an accidental deletion of a folder, we recommend leaving this setting turned on. |
Delete Folder Shortcut |
Prompt when a folder shortcut is deleted. |
Close Local Browser | Prompt when a Local Browser is closed. |
Close Remote Browser | Prompt when a Remote Browser is closed. |
Download Overwrite |
Prompt when a download operation has encountered a file that is about to be overwritten. In order to prevent an accidental overwrite, we recommend leaving this setting turned on. |
Upload Overwrite |
Prompt when an upload operation has encountered a file that is about to be overwritten. In order to prevent an accidental overwrite, we recommend leaving this setting turned on. |
Auto Upload Overwrite |
Prompt when an automatic upload operation has encountered a file that is about to be overwritten. In order to prevent an accidental overwrite, we recommend leaving this setting turned on. |
Upload Newer Files Only (No Overwrite Prompt) |
Only prompt when an upload operation has encountered a newer file that is about to be overwritten. |
Download Newer Files Only (No Overwrite Prompt) |
Only prompt when a download operation has encountered a newer file that is about to be overwritten. |
Disconnect |
Prompt when a remote server is about to be disconnected. |
Delete Site Profile | Prompt when a site profile within the Site Profile Manager is about to be deleted. |
Prompt for Wizard if No Site Profiles | When no site profiles are defined within the Site Profile Manager, FTP Voyager will prompt the user to create one with the New Site Wizard. |
Close FTP Voyager |
Prompt when FTP Voyager is about to close. |
Close FTP Voyager - File Operations in Progress |
Prompt when FTP Voyager is about to close and there are file operations in progress. |
Delete Event |
Prompt when an event is about to be deleted. |
Remove Queue Item | Prompt when an item is about to be removed from the Transfer Queue Pane. |
Open More than 20 Items at Once |
Prompt when more than 20 items are about to be opened within the same open operation. |
Create Folder |
Prompt when a folder is about to be created. |
Reconnect to Upload File |
Prompt when FTP Voyager must reconnect to a remote server in order to upload an incomplete file. |
Discard Local File Copy |
Prompt when FTP Voyager is about to delete a temporary file that was used to open a file on the remote server. |
Open Files Pane Explanation |
Prompt when FTP Voyager is about to open a file on the remote server. |
File Already in Open Files Pane | Prompt when the same file is already opened within the Open Files Pane. |
No Items Match Search Criteria |
Prompt when the search routines don't find any matches pertaining to the search criteria used. |
