Log
Log options allow you to configure the type of information shown in the log pane and how log information is saved to disk.
Note: Many options may be overridden within the Log category within the "Advanced Options" of a site profile located within the Site Profile Manager.
Options pertaining to this page are described below:
Font and Color
The Font and Color section allows you to specify the font and color pertaining to information that is written to the on-screen log.
Adjust the fonts and colors of the items below to produce the desired effects:
- Status Font
- Error Font
- Command Font
- Reply Font
File Logging | Set to "Enabled" if you would like to save the log to a file on your local hard disk. |
Log File Directory | Specify the directory where the log file is stored. |
Timestamps | Select whether the log shows timestamps. The options available are: "No Timestamps", "Full Timestamps", or "Timestamp Only Changes". |
Timestamps Format | Select the format for timestamps. The options available are: "No Milliseconds" or "Include Milliseconds". |
Prompts | Select the format for prompts. Available options are: "Full Prompts", "Abbreviated Prompts", or "No Prompts". |
Log Items
Select which items are logged and what medium they are logged to. Each item under this section can be logged to: the screen, a log file,
both, or neither. Several items can be logged which are:
- Status Messages
- Error Messages
- FTP Commands
- FTP Replies
- SSH Commands
- SSH Replies
- SSH Detail Commands
- SSH Detail Replies
- HTTP Commands
- HTTP Replies
- Raw Listings
Defaults Button
Press this button to reset all settings, on this page, back to their original settings.
