Connection
The Connection category contains many settings that allow you to configure how connections are created and maintained. Settings configured at the global level apply
to all sites. Options pertaining to this page are described below:
Many options may be overridden within the Connection category within the Advanced Options of a site profile located within
the Site Profile Manager.
General
After File Change
Specify how files are handled when FTP Voyager detects an "open file" modification of a remote file.
Force PASV Mode
Specify how FTP Voyager is supposed to handle the data connection for remote server connections. PASV Mode instructs the server to open another connection, and tells
FTP Voyager where to connect. The PORT command instructs the server to initiate a connection TO the client. (For more information, please see the Help documentation
within the Learn About Protocols section.)
Force PASV Mode has three options which are described below:
Automatic
When a "passive" (a.k.a. PASV Mode) data connection fails for any reason, FTP Voyager automatically attempts a connection using the "active" mode (a.k.a. PORT Mode).
Enabled
FTP Voyager establishes a data connection to the server using the PASV port that was returned from the server.
Disabled
The server establishes a data connection with FTP Voyager with the information supplied within the "PORT" command that was sent to the server.
Connection Saver
FTP Voyager normally uses multiple connections or logins for file transfers. By selecting this option, FTP Voyager uses only one connection. You would enable this option if your FTP Server allows you to login only
once. If, while performing file transfers, you get a message that says you're already logged in or you login not accepted, enable this feature.
Remote Tab Reconnect
Select "Yes" to open Remote Browser windows upon startup that were previously open when FTP Voyager was closed.
Connection Timings
Timeout
The time during which FTP Voyager waits for a response from the server for a connection attempt. If a server does not respond to a connection request in this timeframe, FTP Voyager considers
that the connection attempt has failed.
Retries
The times that FTP Voyager retries a failed connection before giving up and informing the user of the failure.
Delay
The number of seconds FTP Voyager waits between connection retry attempts.
Transfer Timeouts
Send Timeout
The amount of time FTP Voyager will wait when trying to upload data to the server. After the time is exceeded, FTP Voyager will consider the transfer failed.
Receive Timeout
The amount of time FTP Voyager will wait when trying to download data from the server. After the time is exceeded, FTP Voyager will consider the transfer failed.
Idle Timeout
The amount of time FTP Voyager will wait until unused worker threads are cleaned up.
Keep Alive
Keep Alive
Select this option if you want FTP Voyager to attempt to keep the FTP connection alive. This is done by occasionally asking the FTP server for its current directory.
Send After (seconds)
Specify the amount of time between sending the "keep alive" command to the FTP Server.
File Transfer
Number of Workers
Specify the number of worker threads that are actively processing the Transfer Queue Pane. Valid values range from 1 through 9.
Download File Tries
If a download fails, FTP Voyager will try to resume the download automatically up the number specified here before discontinuing the transfer.
Upload File Tries
If an upload fails, FTP Voyager will try to resume the upload automatically up the number specified here before discontinuing the transfer.
XCRC Checking
When enabled, FTP Voyager uses an XCRC check to verify the transfer of a file. If a downloaded or uploaded file transfer results in the XCRC value not matching between
FTP Voyager and the server, FTP Voyager attempts to upload or download the file again. FTP Voyager attempts this operation only when enabled and only when
FTP Voyager identifies the server as supporting XCRC, usually through the results of the FEAT command.
Transfer Mode
Determine which mode with which files are transferred to the server. For more information, please see Auto ASCII Extensions within the Options dialog. The options are described below:
Binary |
Use this setting to transfer files without conversion. This mode is used when ASCII text files are not being transferred, or files are being transferred to and from compatible
operating systems.
ASCII
Use this mode to convert a file to a compatible ASCII mode on the destination. For example, [CR][LF] sequences are converted to [LF] sequences when transferring from a Windows operating system to
a UNIX operating system. |
Automatic ASCII
Use this option to automatically change from the binary transfer mode to the ASCII transfer mode. This only applies to files that have a file extension defined within the Auto ASCII Extensions section
of the Options dialog.
Transfer Rate
Limit Upload Rate
Select "Yes" to enforce a transfer limit pertaining to uploads. This is useful to limit the maximum upload bandwidth used by a given site in situations where upstream bandwidth is limited and must be available for other
applications and services.
Max. Upload Rate (KB/sec)
Enter the maximum number of kilobytes that can be uploaded per second.
Limit Download Rate
Select "Yes" to enforce a transfer limit pertaining to downloads. This is useful to limit the maximum download bandwidth used by a given site in situations where downstream bandwidth is limited and must be available for other
Max. Download Rate (KB/sec)
Enter the maximum number of kilobytes that can be downloaded per second.
Compression
Compression Mode
FTP Voyager supports two compression levels - zlib compression, or no compression. By default, FTP Voyager automatically selects "zlib", but will disable compression if the remote server
does not support it.
Compression Level
The higher the compression level, the longer the data takes to encrypt but the less space it takes up in transit. FTP Voyager uses an optimized level of 6 by default.
Defaults Button
Press this button to reset all settings, on this page, back to their original settings.
