Advanced
This page contains advanced settings pertaining to remote file server connections.
Options pertaining to this page are described below:
General
Anonymous Password | Enter the password used for "anonymous" FTP logins. |
Port Range
Limit Port Ranges | Select "Yes" in order to define a Starting and Ending port range for incoming connections. |
Starting Port | Enter a valid port number which is smaller than the "Ending Port" number. The valid range is between 1 and 65535. |
Ending Port | Enter a valid port number which is larger than the "Starting Port" number. The valid range is between 1 and 65535. |
Public IP
Use Public IP | Select "Yes" if you would like FTP Voyager to use a public IP address when connecting to a remote server. |
Server Address | Enter the public hostname or IP address to the remote server. |
Defaults Button
Press this button to reset all settings, on this page, back to their original settings.
