Alternate Editors
The Alternate Editors page provides a way for FTP Voyager to open or edit files with a custom editor of your choosing, instead of the default editor provided by the operating system for a particular file type.
Buttons are located at the top of the list that manage the corresponding editors. The buttons located within the editor list are described below:
New |
Click to use the Editor dialog to define an alternate editor tool for particular file extensions. Please see the Editor dialog for more information pertaining to the creation of an alternate editor. |
Delete | Click to remove the selected item from the corresponding list. |
Move Item Up | Click to move the selected item above another item until the item is at the very top of the list. |
Move Item Down | Click to move the selected item below another item until the item is at the very bottom of the list. |
