Folder Shortcut Dialog
The Folder Shortcut dialog allows you to create a folder shortcut that maps to a location on the remote server. More information can be found within the Folder Shortcuts page located within the Site Profile Manager.
The controls for this dialog are explained below:
Path | Specify the path that corresponds to a directory located on the remote server. |
Display Name |
OK | Click to create a Folder Shortcut which is added to the Folder Shortcuts page located within the Site Profile Manager. |
Cancel | Click to cancel the creation of this rule. |
Help | Click to launch the help documentation. |
