Editor Dialog
The Editor dialog allows you to create an alternate editor for a particular file type; instead of the operating systems default editor. Alternate Editor rules are defined within the Alternate Editors category under the Advanced Options of the Site Profile Manager.
The controls of this dialog are explained below:
File Extension | Enter the file extension(s) that are to be launched within the alternate editor program. Multiple file extensions can be specified by separating each one with a semi-colon. |
Editor Path | Specify the fully-qualified file path to the program that opens the file types specified within the "File Extension" field. |
OK |
Cancel | Click to cancel the creation of this rule. |
Help | Click to launch the help documentation. |
