Custom Command Dialog
The Custom Command dialog allows you to create a custom command that can be sent to a remote server. For more information pertaining to custom commands, please see Custom Commands category under the Advanced Options of the Site Profile Manager.
The dialog controls are described below:
Name | Enter the name of the custom command. |
Command | Enter the FTP command to issue to the server when this custom command is executed. |
OK | Click to create an Custom Command rule which is added to the Custom Commands category under the "Advanced Options" of the Site Profile Manager. |
Cancel | Click to cancel the creation of this rule. |
Help |
