Search Bar Overview
The Search Bar allows you to look for files within the current working directory. The search routines can be configured with various options, like the inclusion of searching all sub-directories or ignoring letter case and more.
The Search Bar controls are described below:
Search Field |
The Search Field allows entry of search criteria, including file and folder names. Once a search has been performed, it is added to a history list that is accessed by clicking on the arrow located on the right-side of the Search Field. Standard wildcards can be used to search for files, populating the listing with all file and/or folder names that match the search criteria. The wildcards are described below:
Search Button |
Click this to start a search within the current working directory based on the filters and options provided. This button also contains hidden controls that can be shown by clicking on the arrow located on the right-side of the button. The hidden controls allow you to refine your search parameters even further and are described in detail below:
