File List view
All files and folders of the current working directory are shown within the File List view of the browser. The file list view has many features that are used to manage the underlying file system. One feature is providing a valid drag and drop location for file paths. Dragging a folder from the Folders pane and dropping it into another valid drop location for file paths produces either a move, copy, or transfer operation. Other features include:
- Creating a new directory
- Deleting a directory
- Renaming a directory
- Opening a directory to view its contents
- Viewing the properties of a directory
- Transferring a directory to another local or remote location
- and more...
The image below shows you an overview of the file listing. You can select multiple files and folders within the file listing by using the mouse or the keyboard. Right-clicking within the listing produces a pop-up menu with many options that can be applied to the selected items.
Several views are provided that change the look and feel of the files and folders being displayed. These are:
