URL login and auto load parameters
In the Web Client you can send login credentials and special load parameters in the URL pointing to the Serv-U File Server. The following list contains the parameters that you can add to the URL:
- Use the "thumbnail=1" parameter to start the Web Client in thumbnails mode after login.
- Use the "slideshow=1" parameter to start the Web Client slide show immediately after login.
- Use the "playlist=1" parameter to play audio files immediately after login to the Web Client.
- Use the "playmedia=1" parameter to play video files immediately after login to the Web Client.
- Use the "dir=" parameter to navigate directly to any directory immediately after login to the Web Client.
- Use the "file=" parameter to download a file located in the directory specified in the "dir=" parameter immediately after login to the Web Client.
- Use the "sortcol=x" parameter to start the Web Client with files or folders sorted by name (1), size (2), or modification date (3). Replace "x" with the number 1, 2, or 3 which matches the sorting you want.
Example URL: http://www.example.com?user=temp&password=temppw&thumbnail=1&dir=/D:/temp/&file=textfile.txt
